bleeding breaks after replacing master cylinder?
Old Jul 26, 2012 | 11:05 AM
Cian Mcloughlin's Avatar
Default bleeding breaks after replacing master cylinder?
just wondering is there a different method too bleeding the brakes after replacing a master cylinder than bleeding it normally?
Old Jul 26, 2012 | 12:12 PM
Mitchness's Avatar
Default Re: bleeding breaks after replacing master cylinder?
Did you remember to bench bleed the MC before you installed it?
Old Jul 28, 2012 | 01:16 PM
no??
Old Jul 28, 2012 | 03:33 PM
JNocon's Avatar
I'll loan u my service dealer manual, if u wanna bleed ur brakes. I gotchu!!!
Old Jul 29, 2012 | 03:14 AM
is it just the standard bleeding method or different because i replaced master cylinder?
Old Jul 29, 2012 | 04:09 AM
beecee18's Avatar
It is different,
you need to carefully clamp down the master cyliner on a work benchtop, and manually bleed the unit before installation,
then do the rigourous bleeding procedure to all four corners, sounds hard, but its really not.
But must be done correctly
you can find a writeup or service manual exerpt to do this by searching, or get the exerpt from the stand up dude above willing to lend it to you
Apr 5, 2018 11:34 AM
thecruzs2007@yahoo.com
Mar 20, 2010 03:52 PM
miataguy
Jul 8, 2003 09:00 PM
Doctor CorteZ
26
Oct 23, 2002 11:28 AM
