How to fix my rear tai light?
Old Oct 15, 2002 | 02:31 PM
ragejed's Avatar
Default How to fix my rear tai light?
Stupid acura warrety is up, and now Im under the extened acu-care warrenty ((( My drivers side tail light has all water in it, and condinsation acura wont replace them either!!! wtf!
How would I go about fixin this problem?
Old Oct 15, 2002 | 02:54 PM
ragejed's Avatar
Default Re: How to fix my rear tai light? (ragejed)
ttt? lol I know I just drain them, but its not just in the part where the bumb goes, its like sitting in the rest of the light, u can see like a water line from the outside, lol, kinda like a fish bowl
Old Oct 15, 2002 | 04:01 PM
ragejed's Avatar
Guys? anyone? I searched for "tail light" and "tail light water" found ****
Old Oct 15, 2002 | 04:35 PM
John-GSR's Avatar
Try drilling a small hole on the bottom to let the water out. Also check the molding around the light. Try to find out what is causing the condensation.
Old Oct 15, 2002 | 05:23 PM
ragejed's Avatar
Default Re: How to fix my rear tai light? (John-GSR)
Not sure If I want to drill a hole in the light, There A way I can take off the old silicone seal and put a new one on?
Also how Do i fix a sinkin taillight? My right light sank, and now touched the metal piece that the trunk key hole is on
Old Oct 15, 2002 | 08:13 PM
wanna b R's Avatar
buy a new one
Old Oct 15, 2002 | 08:20 PM
TurboTurtleGSR's Avatar
I would try to get that one light off of ebay, junkyard, or friend. If you have a lot of time, just take out the whole taillight and pry away at the seal and melt them with a heat gun. Clean out the inside really good and seal them back up. Make sure there are no cracks or holes that might make the fog up again.
Old Oct 16, 2002 | 02:39 AM
ragejed's Avatar
Default Re: How to fix my rear tai light? (wanna b R)
buy a new one
Sure, you got 200 for a NEW one? heh, I don't.
I work, pay for my car, and go to college, no money for a taillight, so its gotta be a DIY fix.
Old Oct 16, 2002 | 05:30 AM
au-gsr's Avatar
buy some cheap altezzas that come with the foam rubber seals, sell the altezzas at the local swap meet and use the seals that came withthe altezzas. the factory charges 70 dollars a piece for those foam rubber seals, tell me they are not tryin to rip people off. i had the same problem, didn't realize how bad it was till i opened my trunk because i heard an ocean of water sloshing around in my spare tire area. there was literally 5 gallons of water back there and i was pissed. but the foam rubber seals fixed it so good luck.
Old Oct 16, 2002 | 06:36 AM
ragejed's Avatar
Default Re: How to fix my rear tai light? (au-gsr)
What foam rubber seal?
http://www.acuraautomotiveparts.net/...gry5=TAILLIGHT
Number 4 is what I need? its only $22....
Old Oct 16, 2002 | 07:14 AM
ALF's Avatar
ALF
Yup. I had the same problem. All you have to do is drain all the water out. Use a blow dryer. It can take up to 20-30 min. so be patient. Then install the new gasket and you're good to go. Or you can do what I did: clean and flex the old gasket and reinstall. Mine has held up to this day since I did it 3 years ago.
Old Oct 16, 2002 | 07:48 AM
ragejed's Avatar
Default Re: How to fix my rear tai light? (ALF)
Its just tha stupid gasket? jeez, I thought the les seal had a crack, and i had to reseal it.
Old Oct 16, 2002 | 07:57 AM
timmy8151's Avatar
You can get a used tailight for about $60-75, you just got to look around.
I bought a whole set for $115 shipped.
Old Oct 16, 2002 | 08:20 AM
ragejed's Avatar
Default Re: How to fix my rear tai light? (timmy8151)
I dont have money for new lights, 20 bux for a new seal sounds more cost effice dont ya think?
Old Oct 16, 2002 | 09:07 AM
Chris's Avatar
The seal should be all you need.
Old Oct 16, 2002 | 09:33 AM
ragejed's Avatar
Default Re: How to fix my rear tai light? (Chris)
Sweet, you guys are great
Old Oct 16, 2002 | 12:32 PM
au-gsr's Avatar
the glue or seal **** they use from the dealership rarely goes bad it is always the foam rubber gasket you can go to Michael's- a craft store - and find the same material you need, trace the design on there and cut it out for about 10 bux total. NOW THAT'S A BARGAIN!!!!!
[Modified by au-gsr, 1:36 PM 10/16/2002]
AndyD
Aug 3, 2010 02:18 PM
Wsteun
Jun 28, 2006 01:18 PM
skata89
Oct 20, 2005 05:50 PM
krncoolwater
May 8, 2002 05:31 AM
