95 civic b20 swap throwing codes 3,4,41
Old Jul 25, 2012 | 03:09 PM
94_civic_dx's Avatar
Default 95 civic b20 swap throwing codes 3,4,41
95 civic 97 jdm b20b swap converted to obd1..95 integra ls ecu stock throwing codes:
3,4,41
3- map sensor
4- crank position sensor
41- primary oxygen sensor heater
Brand new obd1 dizzy with all new parts gonna replace map sensor but how do I fix codes 4 and 41 stuck in limp mode and it won't go past 3k rpm everything is plugged in correctly to my knowledge any help is appreciated thanx
Old Jul 25, 2012 | 03:11 PM
Dc4LsTeG's Avatar
EK9
Default Re: 95 civic b20 swap throwing codes 3,4,41
Is the crank sensor hooked up?
Old Jul 25, 2012 | 03:25 PM
If ur talkin the one on the oil pump no because there isn't one on the jdm motors I thought ?? (correct me if wrong)
Old Jul 25, 2012 | 09:42 PM
First.EG's Avatar
You shouldn't be getting code 4 if your obd1. That leads me to believe that you dizzy is faulty.
Old Jul 26, 2012 | 04:35 AM
It is a brand new dizzy but I guess that's possible I'll try another one n see thanx for the help
Old Jul 26, 2012 | 04:49 AM
That would cause the car to go into limp mode ??
Old Jul 26, 2012 | 10:31 AM
Jimster480's Avatar
CPS will put it in limp mode yes.
hondaclown
Jul 17, 2023 08:14 AM
Thorshammer
Jun 12, 2012 09:39 AM
88_T-Rex
11
Sep 2, 2010 05:20 PM
Quarter Performance
Nov 30, 2008 07:37 PM
rev2ninetyper
Jul 29, 2004 10:37 AM
