93 Civic - What adhesive to use for reinstalling plastic inner door seals?
Old Jul 24, 2012 | 10:00 PM
fragmare's Avatar
Default 93 Civic - What adhesive to use for reinstalling plastic inner door seals?
You know, those thin plastic sheets that seem like they're made of the same material as shower curtains that you have to rip off when fixing the door handle or lock mechanism? When you put new ones back on, what adhesive should I be using? Permatex weather stripping adhesive or equivalent? The manual simply states to use "adhesive" but makes no mention of what kind to use that I can find. Here's a pic for reference:
Old Jul 24, 2012 | 10:12 PM
jbpnoman's Avatar
Default Re: 93 Civic - What adhesive to use for reinstalling plastic inner door seals?
Anything that can stand up to heat and humidity will work just fine, although I'm sure Honda has their own sealant, if you're that much of a purist.
Old Jul 24, 2012 | 10:16 PM
DM7's Avatar
DM7
This guy has a write up on vapor barriers and suggests using 'butyl tape'.
http://www.tegger.com/hondafaq/doorseal/index.html
Old Jul 24, 2012 | 10:20 PM
kwijibodavid's Avatar
id probably use somthing along the lines of a silicon caulk like the kind u would use to seal a tub surround. it will do good with the humidity and moisture and its fairly sticky
Old Jul 24, 2012 | 10:21 PM
jbpnoman's Avatar
Butyl tape would work wonderfully, it would just be a bit on the overkill side. That's the kind of stuff used to seal headlight housings. If your body panels are seeing as much heat as headlight housings do, you have other things to worry about. Namely, why your car is trying to broil you and serve you for dinner.
Either way, it can be found online for pretty cheap, so in this case overkill wouldn't be a bad thing.
Old Jul 24, 2012 | 11:03 PM
fragmare's Avatar
Yea, I don't need anything fancy, just something that'll last for years and keep the rain out and the warm/cool air inside the car. I recently rebuilt my A/C compressor and installed a new drier and recharged the system, so I've got cold A/C now. I'd like that cold air to actually stay in the car, so I'll need to replace the plastic covers that i removed previously for fixing the door handle mechanisms. Interesting writeup there, though. Butyl tape does sound like a good deal if a $10 roll will be enough for both doors (i have a 2 dr)... hmm
Old Jul 24, 2012 | 11:06 PM
jbpnoman's Avatar
Roughly 7 feet per door, if I'm eyeballing it correctly. Probably a little less. a 20' roll should do the trick just fine.
Old Jul 25, 2012 | 03:56 AM
fragmare's Avatar
Here we go: http://www.dkhardware.com/product-83...utyl-tape.html
$5.09 + shipping for a 15' roll
Old Jul 25, 2012 | 04:00 AM
gzes's Avatar
Super glue? $1.00 at dollar tree
danteisme
Jul 7, 2015 04:16 AM
Jaydeep
Apr 23, 2011 10:16 AM
realmike15
Honda Civic (2001 - 2005)
Apr 4, 2011 07:49 PM
simplegreenmachine
Nov 27, 2005 04:55 AM
pbcdb
Audio / Security / Video
17
Jan 17, 2004 09:42 PM
