Prelude Injector size....proof that they are 290cc/min.
Old Oct 15, 2002 | 01:58 PM
Austin's Avatar
Default Prelude Injector size....proof that they are 290cc/min.
Just to give you some proof that the '97+ Prelude injectors are indeed 290cc/min @ 43 psi.
Austin
copy and past this link into your browser for a full size picture : http://www.imagestation.com/picture/...f.jpg.orig.jpg
Old Oct 15, 2002 | 02:02 PM
non-VTEC's Avatar
Default Re: Prelude Injector size....proof that they are 290cc/min. (Austin)
awesome...............
is there anyway to tell the prelude injectors apart from normal integra injectors?
Old Oct 15, 2002 | 02:04 PM
Austin's Avatar
Default Re: Prelude Injector size....proof that they are 290cc/min. (non-VTEC)
Nope...they look the same.
Old Oct 15, 2002 | 02:47 PM
D's Avatar
D
Where is everyone ******* sourcing these bitches? i'm a broke *** btw.
D
Old Oct 15, 2002 | 03:00 PM
Austin's Avatar
Default Re: Prelude Injector size....proof that they are 290cc/min. (D)
D...I was able to get mine from a Honda-Tech regular that had a customer that recently added a turbo kit to their Prelude.
You can usually obtain them from a reputable junk yard, just make sure that you specify '97+ Prelude injectors.
Austin
Old Oct 15, 2002 | 03:02 PM
Tommy_Gunns's Avatar
How much do injectors usually cost? I want to get an idea before I got out and get ripped off.
RC 310 = ?
New Prelude = ?
Junk Yard Prelude = ?
etc.
Old Oct 15, 2002 | 03:06 PM
D's Avatar
D
Thanks for the reply austin
Old Oct 15, 2002 | 03:10 PM
Austin's Avatar
Default Re: Prelude Injector size....proof that they are 290cc/min. (Tommy_Gunns)
Typical prices are $150-175...they are direct bolt-ons, no changing, or soldering of the injector harness is necessary. I'm almost positive that the '96+ NSX injectors are also 290cc/min and are direct bolt-on parts.
Austin
Old Oct 15, 2002 | 04:44 PM
Gong Show's Avatar
These are obdII right? What would have to be done to get these on a obdI set-up. Or if the obdII's go on, how rich will I be?
Old Oct 15, 2002 | 05:32 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: Prelude Injector size....proof that they are 290cc/min. (GONG SHOW)
How much did the flow test/cleaning/whatever from RC cost? Thinking about refreshing Da Gun
Old Oct 15, 2002 | 07:29 PM
Gong Show's Avatar
Default Re: Prelude Injector size....proof that they are 290cc/min. (Splat)
Old Oct 15, 2002 | 09:31 PM
Austin's Avatar
Yes, these are OBDII, sice you have ODBI I would just purchase some RC injectors. You will need a reprogrammed ECU, or a FPR with VAFC/SAFC to compensate for the additional fuel.
Austin
Old Oct 15, 2002 | 09:33 PM
Austin's Avatar
Pat...I believe it to be $25 per injector for the balance and blueprinting.
Austin
Old Oct 15, 2002 | 10:45 PM
Gong Show's Avatar
Austin
Cool, I have the V-AFc and a FPR... And should be getting my ECu chipped by the time I get the injectors.
Old Oct 16, 2002 | 04:19 AM
REDNECK TYPE-R's Avatar
RC 310 = ?
New Prelude = ?
etc.
Old Oct 16, 2002 | 04:36 AM
Doctor CorteZ's Avatar
you also need the injector plugs , they ARE different.
Old Oct 16, 2002 | 04:51 AM
AssPenny's Avatar
Default Re: Prelude Injector size....proof that they are 290cc/min. (Doctor CorteZ)
I picked up mine from the classifieds on here for 150 Just keep your eye out, they come up for sale every once in a while. I believe they have to be the 97+ versions, not possitive on that thou.
Old Oct 16, 2002 | 07:57 AM
Austin's Avatar
For all OBDII cars('96+ Integra) the '97+ Prelude injectors are direct plug-in...the RC injectors are direct plug-in for the '94-95 Integra, but require soldering of new plugs for the '96+ Integra.
Austin
Old Oct 16, 2002 | 10:08 AM
pinota's Avatar
I´ve installed my 97+ lude injectors yesterday. They fit prefectly and they look like stock 240cc injectors. I got them cleaned and they´re perfect. They make 4 fuel jets.
They fit fine in the B18C6 euro ITR.
I´m running now 45 psi, about 300cc.
Padawan
Jun 25, 2011 11:31 PM
90efhatch
Apr 21, 2008 01:07 PM
Turbohatch
Sep 27, 2001 06:12 PM
