Has anyone used this tool set for their front end?
Old Jul 24, 2012 | 08:30 AM
eurochoi's Avatar
Default Has anyone used this tool set for their front end?
I'm thinking of buying this set for use on my Civic and, well anything else that may come up in the future with friend's/relative's vehicles. Do you guys see any blaring reason as to not buy this set for ball joint replacement?
http://www.amazon.com/OTC-6295-Front...pr_product_top
Old Jul 24, 2012 | 08:33 AM
Former User's Avatar
Default Re: Has anyone used this tool set for their front end?
Not sure you need all of those tools if your only goal is to separate the ball joints. The rightmost tool alone is sufficient.
Old Jul 24, 2012 | 08:37 AM
eurochoi's Avatar
Yeah, I have a fork to separate the ball joints, but it seems to always tear the boot, that may be my technique more than the tool though. But I'm looking to replace the ball joint (press out) as well.
Old Jul 24, 2012 | 08:42 AM
Fork? Post a picture. I purchased the ball joint separating tool (identical to one recommended in service manual) and have never damaged a boot. Just grease it up and slide it on.
You can get a free rental of this tool set at AutoZone.
Old Jul 24, 2012 | 08:44 AM
eurochoi's Avatar
These lovely things here.
Old Jul 24, 2012 | 08:45 AM
This^ tool guarantees boot damage. Don't use it.
Get this:
http://www.harborfreight.com/3-4-qua...tor-99849.html
Old Jul 24, 2012 | 08:49 AM
eurochoi's Avatar
Get this:
Noted! I wish I would have known about other tools years back, it would have saved me some work. That "fork" type it just comical at best when trying to separate a ball joint that is really bound. Thanks though, I'll look into renting, they also have the separator on Amazon that is sold separately from the kit....actually your link is a bit cheaper for the same tool.
Old Jul 24, 2012 | 08:50 AM
kaiba's Avatar
Old Jul 24, 2012 | 09:00 AM
eurochoi's Avatar
Originally Posted by kaiba
Old School lol
Old Jul 24, 2012 | 09:04 AM
^Can fix anything, including misbehaving electrical parts.
Old Jul 24, 2012 | 09:10 AM
eurochoi's Avatar
A friend was trying to get his Expedition to the shipping center to send it off back to the mainland from Hawaii after getting orders to the east coast. He had been having problems with the engine not turning over when he'd turn the key. A mechanic had him replace the ECU and various other parts on it to the tune of over 1200 bucks.
Anyway, he had to get it to the shipping center in an hour before their flight off of the island....it ended up being the solenoid and a tap from my trust craftsman hammer (temporarily) alleviated the issue.
In other words, when in doubt knock the crap out of it with a hammer.
Old Jul 24, 2012 | 09:16 AM
Why did I buy any other tools? What a waste of money. The trusted "fix it hammer" always delivers.
Old Jul 24, 2012 | 09:20 AM
redm3turbo's Avatar
I just borrow tools I dont have....
ie. from places like autozone
or places like lowes. I buy them, use em, then clean em up and give em back. Its a tool loaner program of sorts. Autozone is just alot more unfront about it.
Old Jul 24, 2012 | 09:22 AM
eurochoi's Avatar
Back when I worked on helicopters in the Marine Corps, if you used the wrong tool ie a pair of pliers versus a wrench, you'd be doing the job again just so you'd learn to use the proper tool for the job. Talk about learning fast to do it right the first time and to ask questions before you start a job you're uncertain about.
Old Jul 24, 2012 | 09:28 AM
kyden's Avatar
all you need to separate a civic/integra lower ball joint is a 1/2" ratchet and a jack.
upper ball joint? just a hammer.
Old Jul 24, 2012 | 09:35 AM
redm3turbo's Avatar
I think I might have solved why the military budget is over a trillion dollars a year, lol
Old Jul 24, 2012 | 09:38 AM
redm3turbo's Avatar
Guy I used to work with at a dealer always said...."you dont need more tools, you just need a bigger hammer." lol.
Old Jul 24, 2012 | 09:45 AM
94eg!'s Avatar
#1 Super Guy
Loved
The tool your looking for is called a Tie Rod Lifter. It's like $12 on Amazon.
It's really the only tool you need when working on Honda front suspensions. Just don't tigthen the thing so much it crushes the stud where the cotter pin holes are. I usually keep a nut on the stud while using this tool. As long as the nut keeps spinning freely, I keep tightening the tool. Once the nut starts to bind up from the stud getting squished, I back off with the tool. You will find the nut now spins freely again. After a few attempts, even the most stubborn ball joint will pop out loose.
If you do end up mushrooming the ball joint stud (nut won't go on smooth), you can simply Dremel the threads off the stud from the cotter pin hole down to the tip. Then your castle nut will thread back on just fine.
BTW: These tools will push the ball joint boot further up the stud as you push the fork in. The boot is only rubber and will easily slide back down the stud after your done. Sometimes it's a good idea to replace the boot if it's already torn, or simply pop it off to re-grease the 20yr old ball joint. Upper & Lower ball joint boots are liek $1-2 each from Honda. The tie-rod's ball-joint boots are $5 each for some stupid reason.
Old Jul 24, 2012 | 09:58 AM
eurochoi's Avatar
Thanks for the information, I'm actually replacing both lower ball joints when I replace the CV joints since the boots are already torn (on both CV and ball joint) but I didn't want to tear the upper ball joint boot since they seem fine.
Old Jul 24, 2012 | 05:03 PM
strategy400's Avatar
this
Old Jul 24, 2012 | 07:10 PM
gwl's Avatar
gwl
I usually borrow tools from Kragens or Pep Boys. To separate the ball joints, I use the jack and the ratchet trick.
https://honda-tech.com/forums/acura-integra-6/popping-front-lower-balljoints-other-random-observations-887859/
Old Jul 24, 2012 | 08:21 PM
eurochoi's Avatar
Originally Posted by strategy400
this
For pressing the ball joint out?
Old Jul 24, 2012 | 08:29 PM
jbpnoman's Avatar
There's only two tools anyone needs. A big ****ing hammer, and duct tape. If it moves and it shouldn't, use the duct tape. If it doesn't and it should, use the hammer. Problem solved!
Old Jul 25, 2012 | 04:30 AM
gzes's Avatar
Wd40, a hammer and some ducktape is all you ever need. If it doesnt move then wd40 it and beat it with the hammer. But yea i just go to autozone when i need a tool i dont have. Its basically free besides gas
Old Jul 25, 2012 | 05:17 AM
HondaPartsHero's Avatar
Technical Hero
Don't forget JB Weld
