2000 Civic Failed Smog Test due to High CO
Old Jul 23, 2012 | 08:02 PM
CaseyB's Avatar
Default 2000 Civic Failed Smog Test due to High CO
What are ways to lower the CO in a Honda Civic?
Old Jul 23, 2012 | 08:06 PM
Former User's Avatar
Default Re: 2000 Civic Failed Smog Test due to High CO
^Not enough information. Post the smog sheet and give some background.
Old Jul 23, 2012 | 08:17 PM
CaseyB's Avatar
Test: HC CO% NO
15 mph 6 0.98 153
25MPH 7 0.10 310
I failed on the 15 MPH part of the test. No engine light, replaced spark plugs and distributor cap, changed oil and coolant.
Old Jul 23, 2012 | 08:22 PM
What are the max allowable levels for each pollutant?
Old Jul 23, 2012 | 08:24 PM
jbpnoman's Avatar
Did you get a timing light and verify timing is within spec?
Old Jul 23, 2012 | 08:26 PM
CaseyB's Avatar
At 15MPH: HC 66 CO .57 NO 487
25MPH: 49 .55 774
Old Jul 26, 2012 | 08:56 PM
CaseyB's Avatar
Any thoughts or ideas?
Old Jul 27, 2012 | 05:14 AM
I'm stumped. I would have expected the high CO to be accompanied by high HC, but it is not. Only CO is high. The only thing I could think to do is change the air filter.
Does the sheet have any other information on it? Can you post it?
Old Jul 27, 2012 | 10:16 AM
slowcivic2k's Avatar
Give us a photo of the smog sheet so we can diagnose this further.
Check or replace PCV valve, along with the filter as stated above ,does your engine leak oil from anywhere?
I feel your pain Ron, kinda lost on this one, we really need the sheet.
Old Jul 27, 2012 | 10:28 AM
Chubakon's Avatar
i had the same problem as OP. i replace cap/rotor, spark plug/wires, new o2 sensors & new cat. it failed with high CO level. Tech said it was a bad cat but the cat i replace was in good working condition & came off of an '00 SI.
unfortunately i forgot & left the smog sheet at the station. But from what i "heard" i have to run the car SUPER hot to heat up the cat for it to be in working condition since the cat hasnt been used for more then 6 months.
Old Jul 27, 2012 | 10:56 AM
TIPSY-99civic's Avatar
i had the same problem.. come to find out my catalytic converter had 150k miles on it. it had blown out all the packing inside (the packing inside heats to extreme temps and burns the excess CO produced by your engine) once replaced i passed with flying colors. another "ghetto" easy way of getting threw would be to pull an injector clip,car will run like crap but it pumps straight oxygen threw the systems in turn lowering CO
Old Jul 28, 2012 | 04:29 PM
CaseyB's Avatar
i have replaced the cap/rotor, spark plug/wires, air filter. there is some small oil leakage here and there. after i replaced there was increase in CO measurement.
unable to post pic until I am no longer on trial user status
Old Jul 28, 2012 | 04:32 PM
What gives you this^ false impression? Post the sheet.
Old Jul 28, 2012 | 05:34 PM
CaseyB's Avatar
unable to add any attachments or photos
Old Jul 28, 2012 | 05:35 PM
You are able to post pictures. Describe what you are doing.
If you look carefully, you'll find that the stickies at the top describe two different ways to post pictures.
Old Jul 28, 2012 | 06:39 PM
Please read the stickies (gray highlighted threads) so that you can learn the proper way to post pictures.
Methods:
1) Photobucket
2) Honda-tech Attachments feature.
Old Jul 28, 2012 | 06:53 PM
CaseyB's Avatar
Old Jul 28, 2012 | 07:05 PM
It seems like the engine is getting less air that it requires, leading to increased CO production.
You might want to replace the PCV valve.
How's the idle speed?
Old Jul 28, 2012 | 08:29 PM
CaseyB's Avatar
its idles under 1000rpm. if that's what u mean by idle speed
Old Jul 28, 2012 | 10:43 PM
beecee18's Avatar
pull 1-2 deg timing,
increase idle 50-100rpm.
Old Aug 3, 2012 | 11:37 AM
CaseyB's Avatar
turned out to be cracked exhaust manifold...and bad O2 sensor
Old Aug 3, 2012 | 11:50 AM
This^ is hard to reconcile when you consider the posted emissions data. For example, a cracked manifold would be expected to raise O2 levels in the exhaust, yet O2 levels remained at undetectable levels at both 15 and 25 mph.
And it's still hard to understand how a bad O2 sensor would only raise CO levels without also raising HC levels.
My guess is that either the machine used to measure the emissions gases malfunctioned that day of the test or there was operator error.
Old Aug 4, 2012 | 09:19 PM
beecee18's Avatar
This is extremely possibe
California98Civ
Southern California
Sep 1, 2014 09:54 AM
BenjaminJeffers
Mar 4, 2014 04:01 PM
SI_Ro
Dec 21, 2011 10:36 AM
speedball3
13
Oct 26, 2007 01:21 PM
gokooljapan
Feb 18, 2004 07:39 PM
