Need D16z6 Turbo base map
Sorry guys im new to this, before i ask for a base map, I'd first like to ask what kind of information you may need from me to determine this. But as for now I can tell you:
-D16z6
-gt3076
-38mm wastegate
-standard bore vitara 8.5:1 piston
-crower stage 2 turbo cam
-skunk2 intake manifold
-750cc injectors high impedance
-70 mm Throttle body
-3" exhaust
-93 Octane
Im not sure if you will need the desired boost level either but I'm trying to aim for 15psi
This is gonna be my first time ever tuning my car on a rom editor. I've only done piggy back systems, but im sure its the same concept(minus the ignition timing). I was planning on loading a map as close to my setup as possible to the moates ostrich then tuning it a little here and there myself and if I am satisfied then burn the chip and leave it.
If you guys have any other further advice for me before I start it'd be greatly appreciated as well
-D16z6
-gt3076
-38mm wastegate
-3" exhaust
-93 Octane
Barrett24
13
May 8, 2010 06:17 AM
SLowCrx
Apr 8, 2004 03:04 PM
