Pic request: B series top mount setups with drivers side wastegates
Old Jul 23, 2012 | 05:43 AM
wantboost's Avatar
Who is Mr Robot?
Default Pic request: B series top mount setups with drivers side wastegates
as title states... Looking at getting a used top mount but the wastegate is on the US drivers side of the collector. As I'm not running a backdoor intercooler I fear the wastegate is dead in the middle of where I would have the compressor housing clocked... Not to mention the heat soak from the wastegate. I can combat a good portion of that with ceramic coating and heat wrap but not all of it.
the manifold in question... I guess I could make an elbow but I would be concerned about boost stability. So if you could post up pics of a similar setup that does not run a backdoor intercooler it would be greatly appreciated.
Old Jul 23, 2012 | 11:35 AM
K7-1Ktrevor's Avatar
Loved
Community Favorite
Default Re: Pic request: B series top mount setups with drivers side wastegates
you should be able to just **** the turbo at a slight angle to clear the waste gate and then have a J that goes down towards the frame rail. might take a little bit of fitting but I don't see why it would really be an issue.
Old Jul 23, 2012 | 11:55 AM
wantboost's Avatar
Who is Mr Robot?
I just remembered I have my top mount for my sr20 kayoing around. I'll put my Turbo on it and just hold the wastegate towards the compressor side of the turbo. Should give me a rough idea. I'm running a 25g compressor housing so the compressor outlet bends back towards the centerline of the Turbo. That's my only concern
ej2_coupe
Apr 6, 2015 06:34 AM
flycivicsi
Mar 23, 2013 07:34 PM
mcgee*
Jan 21, 2007 03:28 PM
racer034life
Sep 2, 2005 05:02 PM
