96 itr clutch help please
I posted this in the trans section but no help has been offered.. i have a 96 its swap and trans and i need a new clutch (slipping) ive already decided on the exedy oem replacement due to price and my goal orthe car, my question is ive always been under the assumption that a b series clutch is a b series clutch however on thmotorsports a 99 si and 97 its clutch has a 30 dollar difference, i assume its due to the trq rating but conidering im on a budget would it matter which clutch i order. my mods are intake header and exhaust nothing more and will stay that way, thanks for the help guys, i need to find out so can order it, car is almost undrivable
the specific itr clutch is like 2mm smaller! i have no idea what the deal is with it, why they have two part numbers or much of anything else. i ran a standard ls/gsr clutch on one with no issue. what the difference is in feel? who knows.
with the stage one selling just over $200 now that's also a consideration if you wanted a stronger disc and plate
well i called them and asked and they said its pretty much a gimic type thing.. i asked what i needed and they told me, 5 minutes later i got the oem clutch replaceent kit for 129 shipped for the 98-99 itr (they said its stronger?)
the only guess i MIGHT have on why the itr clutch is 2mm smaller is with oem. if honda spec'd a different clutch on the itr that happened to be 2mm smaller then it's possible that exedy in all their oem copying glory also did the same.
b18c99si
May 14, 2012 02:07 PM
