help removing egr valve
Old Jul 22, 2012 | 08:05 PM
black92cb7's Avatar
Default help removing egr valve
I'm trying to remove the valve to clean it and I can't get it off. I can't get any tool I have into to loosen the bolts and they are mega tight. What's the best way and or tool to get it off?
Old Jul 22, 2012 | 08:12 PM
Hidenplanvew's Avatar
Default Re: help removing egr valve
3/8 impact and pb blaster...
Old Jul 22, 2012 | 08:24 PM
holmesnmanny's Avatar
sockets don't fit on the egr cause of the location of the nuts in relation to the valve. You can try an offset box wrench on the bolts. In a worst case scenario, you might need to just say goodbye to the valve and just bend it back so you can get a better angle on the bolts. Then get another from picknpull.
Old Jul 22, 2012 | 08:26 PM
slomofo's Avatar
GDD Member
6 point wrench to break em free, then spin em off by hand.
You can't use a socket because there's not enough room.
Old Jul 22, 2012 | 08:52 PM
black92cb7's Avatar
I tried a 12point wrench and nothing ill give the 6 a shot. They are 12mm right?
Old Jul 27, 2012 | 01:03 AM
2stripeAccord's Avatar
I had the same problem. We tapped the socket wrench with a hammer gently to get it on tight, then tightened it a little then is loosened right up.
Old Jul 27, 2012 | 11:36 AM
1911Man's Avatar
They are 12mm. I used a box end wrench and did what 2stripe said. I tightened the nuts a little and then turned them counter-clockwise and they came right off. I sprayed the EGR valve with carb. cleaner and the carbon came right off.
You may have bolts on your '92, but my '01 has 2 nuts and the studs stay behind on the engine. If PB Blaster doesn't loosen them up, try Kroil. That stuff's expensive, but it will work when other stuff won't.
93civicsedan
13
May 21, 2012 12:18 PM
1 Civic I
Jul 19, 2010 07:28 PM
sandiegosmoka
Mar 25, 2009 04:15 PM
95_teggygsr
Jan 25, 2009 11:16 AM
mbogosia
Jun 11, 2008 05:07 PM
