91 accord bog no power froma stop
Old Jul 22, 2012 | 11:59 AM
g0tgot's Avatar
Default 91 accord bog no power froma stop
Just had timing belt done , shop advises timing is good.
From a stop the car has no power until I ride it to 2k then the power is there like normal.
It will slowly putt to 2k pissing people off behind me .
idle is good
No misfire
No cel
Egr was cleaned prior for smog
Car ran fine before timing belt replacement ,
Needed front main seal replaced so I did everything for a few hundred
Any takers?
Old Jul 22, 2012 | 12:08 PM
jdmcertified909's Avatar
Default Re: 91 accord bog no power froma stop
have you confirmed that timing is good? just remove the top timing cover to expose the cam gear. and put it to tdc from lower crank mark. and see if cam is tdc as well. also make sure your dizzy rotor is tdc
idle is good
No misfire
No cel
Any takers?
Old Jul 22, 2012 | 12:11 PM
g0tgot's Avatar
Will look tonight Ty
Old Jul 24, 2012 | 11:27 AM
g0tgot's Avatar
Well seems to be off, advanced the timing 100% towards firewall on dizzy, car runs almost 100% now
Chev
Jul 23, 2018 10:56 AM
jse
Jul 8, 2009 05:03 PM
dadrought6
Feb 18, 2009 05:22 AM
sidewayz32
18
Oct 25, 2005 04:06 PM
95greensol
Mar 1, 2005 09:22 AM
