Problem with brakes
Old Jul 21, 2012 | 04:38 PM
chase7687's Avatar
Default Problem with brakes
I've been needing to get a brake job for the past month but haven't the cash to do so. I don't have another car so I'm having to drive my hatch. I always use the hand brake when parking. The other day when I got in my car and released the hand brake and got going I noticed when coming to a stop or going through turns the hand brake light comes on. Why is this happening? I thought the brake might be getting stuck when parking but im not sure. Is this dangerous?
Old Jul 21, 2012 | 04:44 PM
EFnCRX's Avatar
Default Re: Problem with brakes
Pull the plastic ebrake cover off and look for the little switch the brake lever leans on its stuck or broken shouldnt cause any problems other than an irritating light hope his helps man!
Old Jul 21, 2012 | 05:02 PM
chase7687's Avatar
When you say plastic cover... is this the entire middle console?
Old Jul 21, 2012 | 06:13 PM
EFnCRX's Avatar
Remove the plastic cap from the rear ebrake cover carefully not to mar it and remove the screw. There is another cap in front do the same there and wiggle it free gently there should be a small sensor visible unplug it and your brake light should turn off.
dderolph
Jan 10, 2013 12:34 PM
donniebrasco
Oct 5, 2004 07:43 AM
dip-set
Jul 28, 2004 10:54 AM
99PreludeSH99
Dec 13, 2003 09:11 AM
99h8tch
Nov 20, 2003 10:43 AM
