Help!!!93 civic b20 swap no power until 4k
Old Jul 21, 2012 | 11:37 AM
TeGgYBwOi201's Avatar
Default Help!!!93 civic b20 swap no power until 4k
What's going on HT I'm going thru this annoying problem...it's a 93 dx coupe converted manual b20 swap...problem I'm having is while driving I don't have any power until 4k rpm and then it's like I hit a brick wall around 5-6k (bogs terribly)and basically no power what so ever...what can this be?I tried about 4 known working dizzy and 4 known working ecu's same problem really aggravated and annoyed any help would be highly appreciated...
New spark plugs/wires
New o2 sensor
New Pcv valve
New Walbro 255 fuel pump
New fuel filter
Old Jul 21, 2012 | 11:38 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Help!!!93 civic b20 swap no power until 4k
How about you check the timing.
Old Jul 21, 2012 | 11:44 AM
Tdc
Old Jul 21, 2012 | 11:56 AM
Help!!!!
Old Jul 21, 2012 | 12:01 PM
If it helps I pulled the running swap from my 94 teggy running fine didn't touch anything but the engine harness it's not chopped or cut
Old Jul 21, 2012 | 12:03 PM
The Grumpiest
Originally Posted by TeGgYBwOi201
Tdc
Er. There is mechanical AND ignition timing.
Old Jul 21, 2012 | 12:23 PM
Well ignition timing no how will I do that?
MaritimerMitch
Jan 16, 2014 02:37 AM
urnot2brightru
Sep 3, 2013 10:45 PM
thirsk66
30
Sep 6, 2011 10:58 PM
mustang5.slow
23
Jul 26, 2007 12:37 PM
11secdx
Dec 26, 2001 08:20 AM
