guys i really need your help with my car cutting off. 90 ef hatch
Old Jul 21, 2012 | 11:23 AM
ef hatchDUDE's Avatar
Default guys i really need your help with my car cutting off. 90 ef hatch
car starts but then cuts off when you realease the key. i just changed the ignition switch today. any other suggestions???? i really really need help.
Old Jul 21, 2012 | 04:27 PM
93delsold16z6's Avatar
Default Re: guys i really need your help with my car cutting off. 90 ef hatch
maybe the ecu doesnt get power when u take out key? hows main relay?
Old Jul 22, 2012 | 06:03 PM
slowcivic2k's Avatar
Are you talking about the lock cylinder, or the ignition switch, it is the electrical part that fails, which is the ignition switch.
Check your main fuses. Does anything happen before you crank it, in the RUN II position?
Old Jul 22, 2012 | 06:48 PM
crxin's Avatar
do you have a lot of keys on your key ring? I have seen where someone had a ton of keys on there key ring and actually wore out the cylinder, and once let go it actually sprung back to the off position, but it was so close it looked like it was still on.
Old Jul 25, 2012 | 08:06 PM
Civic ef99's Avatar
Check to make sure you have all the proper connections
xaviACCORD
Jan 15, 2013 05:57 PM
nowind
Oct 22, 2006 10:17 AM
benmyfriend
Dec 4, 2005 09:54 PM
J.P.
Mar 11, 2003 05:40 PM
Hondasaurs
Oct 24, 2002 08:03 AM
