1998 CRV won't turn off!!
Thanks for your help in advance!
I have a customer with a '98 CRV that will not turn off with the key! I checked and the ign wire(blk/yel) is staying powered with key off. disconnected ig switch plugs (2) from fuse box, still stays running. Something is causing that circuit to latch. Disconnect battery for a couple minutes, re-connect and ignition circuit is off...cycle the key and ignition wire stays latched again. Any thoughts?!? To recap: turn key off, crv stays running, disconnect switch, stays running...
I would check the distributor, distributor wiring and connectors next.
JuneBugDrfter
Nov 30, 2013 07:57 AM
lsvtechatch92
Apr 6, 2009 10:13 AM
