89 HB rear brake disc conversion
Are the trailing arms from a coupe and sedan the same from an Integra DA? I want to do a. swap on my EF and I cam get ahold of some DA sedan brakes
i jus used my stock on my ef but i put it together from a non rollin shell i dont remember using other lca's but make sure u get the proportioning valve, i was told that the percentage of pressure is different from drum brakes to disc
yea i had read that i had to use my lca but i think the posts i read the guy used the DA trailing arm thats why i was wondering if the DA coupe and sedan where the same ones. Id rather just bolt on a trailing arm than putting all the stuff on mine you know?
well idk if they are the same but they work, my rear disk brakes are from a sedan da, also have the da master cylinder but i still use the stock prop valve because the stock prop on my car the fittings are eroded that they are almost impossible to take off.
yes you can the e-brake cables from the da, im not sure on the dc but i think they mess with the geometry of the vehicle a little i would just stick to da
the original ED/EF ones won't work because they are designed to be used with drum brakes. DA cables will work.
I am actually running DC rear trailing arms and brakes on mine. They fit fine, main difference is the rear hub is a bit larger and slightly wider than the crx si parts. Not sure if it's the same as the DA parts or not though.
EF88Ty
Oct 16, 2018 10:33 AM
OnceIwasMuffin
Jun 20, 2018 06:33 AM
1JDMDOMINICAN
Sep 29, 2005 06:54 AM
