SR20DET P28
Hey guys.
Parts list:
-Brian Crower springs, retainers, and valves
-Meagan Racing manifold
-T28 Turbo
-Cometic head gasket
-ARP head studs
-87mm JE 8.5:1cr 2618 pistons (not srp)
-Eagle rods
-Clevite rod/main bearings
-Spec Carbon Kevlar clutch
-Spec Billet flywheel
-Stock SR transmission
-New OE Nissan water pump
-New OE Nissan oil pump
-New OE Nissan timing kit
-New OE Nissan complete gasket and seal kit
Machine Work:
-Head surfaced
-Block decked w/ oil pump bolted on
-Bore and hone
-Align honed mains
-Micro polished crank
-3 angle valve job
-Balanced rotating assembly
TIG'd SR CPS with a honda vtec dizzy, running Neptune ECU management, tuned by Courtney Green, all done at Element Racing here in Utah. 260whp at 7psi. Factory is 205bhp at 7psi.
It's got a few thousand miles on it now. Throwing a code 9 (awesome.) and this Frankenstein dizzy wasn't cheap haha, although the car is still running like a champ. I also believe I am still retarded on timing, I had to play it by idle/ear. My question is, on Honda civics I understand you guys have a plug you need to jump underneath the dash... Where exactly do these wires go? What pins into the ECU? I obviously do not have this plug, so I have to manually find these wires coming out of the ecu and ground them together that way.
I've been trying to get a hold of the shop but they are busy lately, just seeing if you guys knew. I understand that I can also have the base timing reset by the tuner, but would like to do it myself if possible as I have a drift event coming up.
I'd like to solve these problems so I can get some more power. 300hp should be toasty and achievable with new map sensor and injectors.
Thanks for the help.
Parts list:
-T28 Turbo
-ARP head studs
-Eagle rods
Machine Work:
-Head surfaced
-Bore and hone
-Align honed mains
-3 angle valve job
blackboostcoupe
Jul 26, 2006 05:12 PM
ludesleep
May 12, 2003 10:13 PM
