best ecu swap choice
Got a h23a1 honda prelude 1993 odb1 automatic transmission. I am currently running the stock p14 ecu. I am swapping for another ecu that is tunable. I am debating between a p74 p75 or p06. What has everyone had the best luck with? Keep in mind auto ecu. Want to install a hondata s300
Auto trannys are not supported on the s300 platform:
http://www.hondata.com/ecus.html
Read note 2 at the end of the table...
I've been able to do it using an auto P75 chipped and tuned with an auto basemap but sometimes the customer gets a blinking D1 light on the cluster even though it shifts fine.
Most of the time, customers swap over to a manual tranny.
ok, rywire can make me a harness so ill be getting a p06 ecu and a rywire (p14 to P06) harness along with hondata s300. think this will work? h23a1 engine. is there any difference between a p06 auto and manual ecu. seems to be the same ecu to me, if so what is the difference if i already have a trans controller?
Yea, its.gona be $250 bucks for the harness $490 for the s300 and about $50-$100 for the p06 ecu. At least this is a good option for what i am doing here, the aem fic is great but my tuner refuses to work with it. I can understand why, It is a pain to tune with, especially on a odb1 honda that makes it very hard to see short term fuel trims. If i did not have a scope and extensive electronics knowledge it would have been impossible. But new and better things are in store now!!!!! Whoooooo!
98savage
May 2, 2007 09:01 PM
accordfreak
Oct 31, 2002 07:21 AM
