'97 EX - Overheating
Old Jul 19, 2012 | 02:47 AM
garciajasmine75's Avatar
Icon6 '97 EX - Overheating
okey well I have a Honda 1997 civic ex that is haveing serious overheating problems. I've changed the thermostat, I've bought New water holes not sure what there called but they where leaking water so fix that. and I fixing the timing of the tempeture and nothing. after all this I tested out and it didn't over heat. but all of a sudden I took a 14 min drive in the fey and it sprang up so quick to the heat and even to the red line all the way to the top . Idk wat it is raidiator has water help wanted please
Posted from Honda-tech.com App for Android
Old Jul 20, 2012 | 04:52 AM
Jimster480's Avatar
Default Re: '97 EX - Overheating
sounds like you have a headgasket issue. Try doing a leakdown test and see. Also is your exhaust smoking at all? if not then go hold your hand near it and see if your hand gets wet, if it does your headgasket is most likely leaking.
Lenniejohnson
Honda Civic (2001 - 2005)
15
Nov 21, 2015 02:26 PM
FlewByU352
Sep 19, 2015 07:48 AM
allthegoodnamesaretaken
Jul 10, 2007 01:19 PM
