Can anyone help me with my Civic.
I have just replaced the 1493CC motor in my daughter's 1991 civic LX sedan and can't get it to start. It cranks and at first it would sputter but now no spark from the distributor. I have replaced the distributor with a new one (the old one had a lifetime warranty) but still no spark. All the correct voltages are at the distributor but nothing from the timing light when I crank it over. I have looked for the main relay under the dash but no luck yet, they indicate it is under the dash on the left side but nothing that looks like the relay.
Any suggestion on where to start this troubleshooting will be greatly appreciated. http://images.ibsrv.net/ibsrv/res/sr...es/emcrook.gif
Thank you for the picture you made much easier to locate, problem is getting it out. I was having problems getting the electrical plug disconnected so I tried removing the main bracket bolt, and the harness is keeping it hung up. Not wanting to disamble that portion of the dash...should I have disconnected the relay electrical plug prior to the support being removed?
I appreciate your picture of the relay. I'm working through a issue removing the relay so I can do the testing. I have the harness hung up. Do you know if there is a electrical diagram of main relay? The manual I have doesn't show a pin out connection of the relay, do you know a link to that info?
This took two seconds on google, literally....
What motor did you replace it with? Engine code is stamped on the front of the engine, right by the heat shield where the tranny mates up
(also took seconds to find this too... as I figure this will be the next question)
What a hassle.
Does your fuel pump prime when you turn the key to "on"?
Tell tale sign if your Main Relay dies.
Should have checked that before digging about under the dash.
Also, check out the grounds. If you missed any of them, then you aren't getting spark.
Triple check the ground on the thermostat housing!
The motor came from "Engine and Transmission World" and they took the VID number of the car to match the motor so I feel as if I have received the correct motor.
Have you deal with the motor's from "Engine and Transmission World"?
I have read review that say they have a good product but this is my first time using their motors so i believe the trouble is in my backyard.
What a hassle.
Thanks again I really appreciate the input!
I have checked the timing with a compression gage the rotor posiion and the timing marks on the pully they look real close but I don't have a spark at any of the plug wires so I need to address this first.
If you have any other ideas please send them to me I'm...ready to get this running.
Thanks Bro
Thanks Bro
No offense man, but searching will net you the answers much faster usually...
But sometimes when you have been under a dash in the heat you just don't take the time to thinks thing through and just SCREAM help!
Thanks for the print!
What a hassle.
Potentially there may be a background problem which is why you may have swapped out the engine previously.
Why did you put in a new engine?
What engine code is this engine? D15B2?
Do you have any electrical problems other than no spark?
Is your check engine light on?
Is your rotor actually on (inside the cap)? They are notorious for removing themselves and falling off inside the cap. I've had it happen while I was driving down a hill, not fun.
Alternator is good?
Battery is good? I figure your battery is good if your fuel pump is priming and engine cranks...
Also there are 4 grounds... Off the top of my head I can name 3... hopefully someone can chime in with the last....
Thermostat
Battery
Valve Cover
XXXXXX Transmission?
Alternator is good?
Thermostat
Battery
Valve Cover
What a hassle.
Nooch,
I didn't remove the tranmission so I'm hoping that the ground connection is still connected. Is the ground connection inside the engine compartment or under the car?
thanks again!
thanks again!
Thanks Everyone I have it starting and running on it own for a little while. It is running but after about 10 seconds the engine start to tach up and doesn't stop unless I turn off the ignition key. Has anyone seen this problem before? I reset the ECM by removing the fuse to the unit for over a minute so it is reset. Any input will be great I'm really close and need to complete this task.
Again thanks to everyone who has offered suggestion I really appreciate the help!!
Found problem with the tach up, nothing but pilot error and miss adjustment. Everyone thanks again!
CR-Ricks
Jul 17, 2013 03:09 PM
C-RICKS
Aug 15, 2009 06:05 PM
