Help!!! new clutch, still vibrate
Old Jul 19, 2012 | 12:02 AM
dtran002's Avatar
Default Help!!! new clutch, still vibrate
Well, couple weeks ago, I posted my car issue, which is the whole car shake/vibrate when I press on the gas (the same violent shaking as if you have a warped rotor and pressing the brake at high speed). Anywho, I checked and replace both axle, new clutch (exedy oem) and it still the same. Although it is a bit less now, but still there.
So what else should I check for this issue? I really dont know what else, beside replacing the half shaft, which the mechanic did a visual checked and said there was not any damage or any movement of the bearing.
It is a 95 Accord with H22a, all stock.
Thanks
dtran002
Jul 21, 2012 03:12 AM
Mattthepartyboy
Jun 14, 2012 09:16 PM
sjohnsonbcm
Transmission & Drivetrain
May 15, 2012 03:20 PM
DCtito
Sep 3, 2006 10:53 AM
JdmFront619
Oct 28, 2003 12:25 PM
