Suspension & Brakes Theory, alignment, spring rates....
Rear LCA sway bar settings??
Old Jul 17, 2012 | 11:46 AM
crazyjetsfan22's Avatar
Default Rear LCA sway bar settings??
I am currently in the middle of re building my car and was putting on my comptech 22mm rear sway bar on to my F7 lca's and i am unsure of which holes i should put the end link to on the rear LCA.
i see on my F7's it has S, M, H (obviously soft medium and hard) and another hole not labeled below it. unsure what that setting is for
I was just wondering how much of a difference do the settings make? What settings are you using ?
Any information would be helpful!
Here are some pics of my set up
Old Jul 17, 2012 | 06:04 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Rear LCA sway bar settings??
From the F7 website
Three sway-bar mount points are provided to add adjustability in all race conditions
Doesn't say anything about FOUR swaybar mounting points so I probably wouldn't use that one as a mounting point for those endlinks. Especially if it isn't labelled like the other 3.
Best bet? Contact F7.
Old Jul 17, 2012 | 11:33 PM
egsleepercivic's Avatar
start in M then adjust from there whether you want more or less rear bar
Old Jul 18, 2012 | 05:18 AM
Originally Posted by grumblemarc
From the F7 website
Saw some one elses mounted there on a random search. My thought its it might actually be for OEM endlinks? i could be wrong.
Well thats what i plan to do just want an answer from someone who has actually messed with the settings to chime in on the differences they felt.
Old Jul 18, 2012 | 05:23 AM
The Grumpiest
Differences in ride are going to be subjective. You'll never get a real answer as with anything regarding ride quality and suspension.
Old Jul 18, 2012 | 10:28 AM
Very true! well guess i will have to play around with it a bit.
I have realized that the EK lca's are the ones with 4 holes hmm.
phat00civic
Suspension & Brakes
19
Jan 13, 2012 01:51 PM
immajackuup
21
Aug 15, 2008 06:00 PM
triple
May 23, 2006 03:45 AM
viprcr1
Aug 16, 2003 04:58 PM
