Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
08 tl-s code p0171
Old Jul 17, 2012 | 12:11 AM
pakn-heat's Avatar
Icon2 08 tl-s code p0171
Ok.just bought this car weds from a dealer.not honda/acura dealer
Not sure if it was throwing it when purhased or if it came on after..but on Saturday.
The car threw the gas cap light and this p0171 code showed up.I imagine its 2 different
Things because gas cap light went off.but on the messages it says the code
Still.
I been searching and some say vaccum leak some say 02 sensor by cat..
The car has hit around 44k.
And I noticed upon start.it will take probly 4 or 5 turns for iit to start.
Like its hesitant some.
Could it be somthing more than just a 02 sensor?
Should I just order me a 02 sensor and replace?
Has anyone had this code and it end up being 02 sensor?
Old Jul 17, 2012 | 05:18 AM
Tweak01's Avatar
Default Re: 08 tl-s code p0171
I know when the car kicks a code the message will stay in messages until it is cleared out.
I do not know how to clear it because the dealer has always done it.
Old Jul 17, 2012 | 05:22 AM
Tweak01's Avatar
Sounds like there could be a bunch of things to try after reading some of these posts...
http://www.google.com/search?client=...UTF-8&oe=UTF-8
Old Jul 18, 2012 | 06:33 AM
pakn-heat's Avatar
Ya.I got mixed answers...that why I was kinda seeing if anyone one has had this issue
And fixed it by doing certain thing..
Ima try and talk to they dealership and see if they can check it out...sux that..what...3 or 4
Days later cel comes on..probly was on when I bougt it because I didn't even know the car
Stored it and gave alerts.
Kinda makes me feel like I probly bought a lemon
Old Jul 20, 2012 | 02:53 AM
pakn-heat's Avatar
Ok..searched up...guess I don't have a cel?its stored in navi or watever..
I think I found out how to clear the code,but unsure because it says I have to
Reactivate acuralink..
Guess that's why the dealer saiid I have to go to acura dealer to clear it because they
Didn't have equipment.
Has anyone reactivated acuralink?from what it looks I have to go online o customer service.
Old Jul 26, 2012 | 04:35 PM
Nate Dog's Avatar
disconnecting battery doesn't clear it?
Old Jul 31, 2012 | 07:53 AM
lzylst's Avatar
No codes here, but my TLS doesn't start quickly either, but I believe that is normal for the Honda v6.
Old Aug 24, 2012 | 05:15 PM
sauceja's Avatar
It is the emmission evap purge control valve. Alot of good info on how to fix this yourself for the price of the part on acurazine.com
Very common on the 04-08 TL
It is not the gas cap or any other common problems that you would think of. A well documented problem with a fairly easy fix.
Old Aug 27, 2012 | 03:59 PM
kouajones's Avatar
Your TL will need a simple PCM update. Applies To: 2007–08 TL Type–S – ALL
MIL Comes On With DTC P0171 or P0174
REVISION SUMMARY
Under WARRANTY CLAIM INFORMATION, the flat
rate time was changed because the MVCI updates
control modules more efficiently.
SYMPTOM
The MIL is on with DTC P0171 (rear bank [bank 1] fuel
system too lean) or DTC P0174 (front bank [bank 2]
fuel system too lean).
PROBABLE CAUSE
The PCM misinterprets inputs as a lean condition.
CORRECTIVE ACTION
Update the PGM-FI software with the HDS.
SOFTWARE INFORMATION
HDS Software Version: 2.015.018 Sept 2008 (blue) or
later.
Control Module (CM) Update:
Application Version V6.13.09 or later.
Database Update 01-SEPT-2008 or later.
NOTE: If you use an earlier HDS software version, the
HDS may incorrectly indicate that the vehicle does not
need an update when it actually does.
The updated PGM-FI software program IDs and P/Ns
are shown below. If this, or a later program ID, is the
Current Program ID displayed during the update, the
software for this service bulletin is already installed.
The normal warranty applies.
Operation Number: 125517
Flat Rate Time: 0.2 hour
Failed Part: P/N 37820-RDB-A11
Defect Code: 03217
Symptom Code: 03203
Skill Level: Repair Technician
REPAIR PROCEDURE
Update the PGM-FI software with the HDS. Refer to
Service Bulletin 01-026, Updating Control Units/
Modules.
Year/Model Program ID Program P/N
2007 with M/T DBA040 37805-RDB-A04 or later
2007 with A/T DBA550 37805-RDB-*** or later
2008 with M/T DBA120 37805-RDB-A12 or later
2008 with A/T DBA620 37805-RDB-A62 or later
Old Aug 27, 2012 | 04:01 PM
kouajones's Avatar
The Gas Cap with no codes will be this bulletin
Applies To: 2007–08 TL – ALL
Fuel Cap Warning Message Is On Without DTCs
SYMPTOM
A TIGHTEN FUEL CAP message appears on the MID
(multi-information display) without setting any Pending
or Confirmed DTCs.
PROBABLE CAUSE
An intermittent fault in the EVAP canister purge valve
causes the PCM on-board diagnostics for the
evaporative emissions to fail.
CORRECTIVE ACTION
Replace the EVAP canister purge valve.
PARTS INFORMATION
EVAP Canister Purge Valve:
P/N 36162-RDV-J01
REQUIRED MATERIALS
In warranty: The normal warranty applies.
Operation Number: 1201D0
Failed Part: P/N 36162-RDV-J01
Defect Code: 03217
Symptom Code: 03203
Out of warranty: Any repair performed after warranty
expiration may be eligible for goodwill consideration by
the District Parts and Service Manager or your Zone
Office. You must request consideration, and get a
decision, before starting work.
DIAGNOSIS
With the fuel cap warning message on, check for DTCs
with the HDS.
Are there any DTCs?
Yes - This service bulletin does not apply.
Troubleshoot the DTC(s) as needed.
No - Go to REPAIR PROCEDURE.
REPAIR PROCEDURE
Replace the EVAP canister purge valve:
NOTE: The EVAP canister purge valve is located near
the throttle body.
• Disconnect the two hoses and the 2P connector from
the purge valve.
• Remove the purge valve (two bolts).
• Install the new purge valve, and torque the bolts to
9.8 N.m (7.2 lb-ft).
• Connect the 2P connector and the two hoses to the
new purge valve.
EVAP CANISTER
PURGE VALVE
HOSES 2P CONNECTOR
BOLTS
9.8
aelhih
May 26, 2022 11:14 AM
kizner
Jan 29, 2006 09:39 AM
UNDER PRESSURE
Feb 4, 2003 01:07 PM
