95 accord wont start
Old Jul 16, 2012 | 06:11 PM
rkmartin017's Avatar
Default 95 accord wont start
hello im helping a buddy work on his 95 accord and he put a new tranny, from a pull a part i believe, and we put a new starter in and conected the wires and tested the battery and its got power, when i turn the key it almost sounds like the bendix isnt fully touching the flywheel, also hearing a slight grinding sound as it trys to turn over, it wont turn over at all, any ideas? i thought maybe the starter was the wrong one, but the part number matches the right starter, its an auto, with an f22b2
Old Jul 16, 2012 | 06:52 PM
Dioxine's Avatar
Default Re: 95 accord wont start
Make sure the starter isnt in ****-eyed.
Old Jul 16, 2012 | 07:06 PM
slomofo's Avatar
GDD Member
Is the torque converter bolted on?
Old Jul 16, 2012 | 07:29 PM
Hmm i dont believe the torque converter bolts on, doesnt it spline on the tranny?
And I made sure it wasnt on cockeyed.
Old Jul 16, 2012 | 11:16 PM
PearlsOwner's Avatar
fly wheel bolted I would assume he is saying.
Take the starter out and test on the floor, put power from a battery to it and see what happens
Old Jul 17, 2012 | 01:37 AM
holmesnmanny's Avatar
OP do you have an auto or a manual tranny ? Manual trannies have flywheels, auto trannies have flex plates or driver plates. Obviously if it's a manual tranny you don't have a torque converter.
Old Jul 17, 2012 | 11:13 AM
slomofo's Avatar
GDD Member
He said it's an auto in his first post :shrugs:
Old Jul 17, 2012 | 12:17 PM
Im gonna start by having him exchange the starter for a different one and go from there, if that doesn't work i guess were gonna pull the tranny and take a look at the converter.
Old Jul 17, 2012 | 01:30 PM
slomofo's Avatar
GDD Member
Pull the starter off, stick your hand in the hole and see if you can spin the converter around with your fingers. If so, then get under the car and bolt it on. It's like 4 10mm bolts that attach the converter to the flex plate.
If the converter is bolted on, grab a battery and some jumper cables, then test to see if your starter is good.
Old Jul 21, 2012 | 07:34 PM
Dioxine's Avatar
BAM! Perfect explanation for you right there.
Lake Wild
Jan 19, 2018 06:02 AM
dedavis88
Feb 19, 2014 01:39 PM
killerkali420
Mar 30, 2011 04:29 PM
efjones9
18
Mar 11, 2010 12:53 PM
ryanevansoh
Nov 11, 2008 10:28 PM
