OBD1 ECU to OBD2 Alternator
Old Jul 16, 2012 | 12:12 PM
pwr2wh8's Avatar
Default OBD1 ECU to OBD2 Alternator
As my alternator (OBD1) is showing signs of age, I was in the market for a replacement. I came across a high output OBD2 alternator which I read is backwards compatible with an OBD1 ECU. However, as I don't have the typical 4-wire connection, I'm a bit confused on how to wire it's not a direct cross match. See below for my current setup.
Pin 1: White/Blue
Pin 2: Black/Yellow
Pin 3: (empty)
Pin 4: Blue
Based on my setup, would I wire as follows?
Pin 1: Black/Yellow
Pin 2: (empty)
Pin 3: Blue
Pin 4: White/Blue
Thanks in advance!
Old Jul 16, 2012 | 09:59 PM
pwr2wh8's Avatar
Default Re: OBD1 ECU to OBD2 Alternator
BTW, does anyone know if pin 2 White/Yellow (OBD2: White/Green) is required. I found it's for ALT C (alternator control?) and read it's not required.
Old Dec 3, 2012 | 08:40 PM
James71190's Avatar
I have been having the same issue how do I kno what wires to what
Old Dec 3, 2012 | 08:51 PM
James71190's Avatar
The white/green and white/yellow,I'm confused on which pin these go to which pin
Old Dec 20, 2012 | 07:32 PM
1991integrada9's Avatar
Bump
Old Dec 22, 2012 | 10:38 PM
pwr2wh8's Avatar
Referencing the photos I attached in the first post, the following has worked for me.
OBD II Alternator
Pin 1: Black/Yellow (Field Reference)
Pin 2: White/Green (Control)
Pin 3: ---
Pin 4: White/Blue (Indicator Lamp)
In reality, you only need Pin 1 & 2 for the alternator to function.
MotionPicture
Sep 17, 2008 10:34 AM
spoon93
Jun 28, 2008 01:49 PM
Dead CIVIC
15
Jan 28, 2008 05:53 PM
