Squeaky sound from new springs
Old Oct 15, 2002 | 10:11 AM
SickMindedEX's Avatar
Default Squeaky sound from new springs
I had a friend install neuspeed lowering springs on my 95 Accord and now I can hear squeaking coming from somewhere in the suspencion or the chasis, I cant tell, but what could the problem be ?
Old Oct 15, 2002 | 10:18 AM
Stew Pidasso's Avatar
Default Re: Squeaky sound from new springs (SickMindedEX)
Welcome to the world of lowered suspensions...
Edit: And welcome to Honda-Tech
[Modified by Stew Pidasso, 2:18 PM 10/15/2002]
Old Oct 15, 2002 | 10:24 AM
m0t0rhead's Avatar
Default Re: Squeaky sound from new springs (Stew Pidasso)
Hrmph. Mine doesn't squeak
Old Oct 15, 2002 | 05:26 PM
Razor's Avatar
mine used to squeek and make funky noises when i had neuspeed springs with just stock shocks. after i installed the koni yellows there is no more'squeeking' noise, just the occasional clunking noise which is normal if you don't have your springs wrapped.
Old Oct 15, 2002 | 05:29 PM
GimpyAccord's Avatar
Default Re: Squeaky sound from new springs (Razor)
my lowering springs (neuspeed) squeeked. I finally figured out it was loose in the spring isolater up top. I put some black wire loom on the top/bottom and taped it up ... no more squeek! That was 4 years ago almost now. PS: that is using tokiko NA blues.
[Modified by GimpyAccord, 2:29 AM 10/16/2002]
Old Oct 15, 2002 | 05:31 PM
iam7head's Avatar
Default Re: Squeaky sound from new springs (GimpyAccord)
My friend used to have lowering Coilover in his prelude,
it's bad, it make all kind of sounds.
is time to switch to somethings better..h&r or eibach...
just my .02
Old Oct 15, 2002 | 05:47 PM
Nick H's Avatar
New User
Default Re: Squeaky sound from new springs (onetym408)
get some kyb's and either springs or coilovers...most of these guys on here think coilovers are bad...but i'll tell you they aren't so bad...i have mine set up almost all the way and with my kyb agx shocks, they work wonders...the ride is still somewhat sporty with a decently lowered look, and i can drop it down and make the shocks stiffer for autoX whenever i want...it's a good adjustable way of making your car behave differently by easy adjustments...that's just my .02...do what you want though...
Old Oct 15, 2002 | 06:39 PM
Default Re: Squeaky sound from new springs (Nick H)
I love coilovers.. but REAL threaded body coilovers.
Old Oct 22, 2002 | 11:05 AM
Thank everybody, I think I might go for the Koni Yellows.
Old Oct 22, 2002 | 11:24 AM
You won't regret it...
Old Oct 22, 2002 | 11:56 AM
NeKe1's Avatar
i have pretty much the same set up, i have the kyb agx and weapon R coil overs on a 95 and i have no problems at all with the set up, but i also have the dc sport braces and it handles bad ***..... i swear by coil overs.
Old Oct 22, 2002 | 12:15 PM
exr90's Avatar
what does this do?
pitbull
Jun 27, 2004 06:01 AM
ayacht
Oct 20, 2002 10:54 PM
2000GSR
May 6, 2002 11:38 AM
