Honda CR-V & Element 2WD & 4WD Element & CR-V
moded a hytec tri y for awd crv
Old Jul 15, 2012 | 08:14 PM
fitseries3's Avatar
Default moded a hytec tri y for awd crv
i didnt want to be limited to stock or crappy header for my awd gsr crv build so i got the header i wanted, a hytec tri y, and modded it to work around the transfer case. if anyone wants details on how to make it work i'll be happy to share.
Old Jul 15, 2012 | 08:15 PM
fitseries3's Avatar
Default Re: moded a hytec tri y for awd crv
going to have to relocate the O2 bung near the flange but thats easy. i'll clean up the welds before putting it back on the car permanently.
Old Jul 15, 2012 | 08:16 PM
EE2bitsk's Avatar
nice
Old Jul 15, 2012 | 08:31 PM
fitseries3's Avatar
its hard to get a pic of but all that i did was cut the it in 2 different places. one side cleared the transfer case just fine so i cut it near the final collector. the other side that didnt clear the transfer case i cut right after the weld on the first collector(or right past the oil pan). i rotated the whole rear piece 45degrees and tacked it back on the pipe that clears the transfer case then used the section i cut out to bridge the other side. once that was tacked in i cut 2 pie cut pieces of stainless 304 tubing to fit in the gaps then welded it all up. i need to cut off the old o2 bung and weld a new one by the collector.
whole exhaust is going to be 2.5inch using a thunderbolt high flow cat, thrush glasspack and vibrant muffler.
my crv is getting a gsr swap here in a week or so
Old Jul 15, 2012 | 08:55 PM
qwrty's Avatar
thanks for the share...
more pics when its installed on your V! good luck///
Old Jul 15, 2012 | 09:30 PM
Hironakasan's Avatar
Thats awesome! Nice work man.
Old Jul 15, 2012 | 10:20 PM
doood's Avatar
been there done that
i'm no engineer, but those transitions look really sharp. hope you didnt cut up a real hytech header.
Old Jul 16, 2012 | 03:53 AM
LDForget's Avatar
Id have to agree. lol. At least it works i guess, but scavenging from those 2 cylinders will be greatly decreased compared to the other 2. Im likely going to buy a header kit and just make my own from scratch to avoid issues like this.
Old Jul 16, 2012 | 04:49 AM
ARMED's Avatar
nice..... i got the same headers...
Old Jul 16, 2012 | 02:01 PM
black0hatch's Avatar
ya you could have bought some prebent pipe u's and cut that instead of those pie cuts for something a little more flowing.
Old Jul 18, 2012 | 02:26 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
It's not a real HyTech as it should have springs holding the two parts together. The bends are pretty sharp for an N/A vehicle... I don't have any pictures of the one I made years ago, but I can tell you it doesn't have to be that sharp. Either way, it's not going to make 'that' big of a difference with a stock GSR and 2.5" piping.
Old Jul 18, 2012 | 06:14 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
wow that is great man!!
Dc2_ShowStopper
Mar 30, 2013 07:22 AM
Conan the Destroyer
15
Mar 26, 2009 04:12 PM
H8 O ATE
Sep 11, 2007 02:34 PM
Coomer
Welding / Fabrication
10
Jul 22, 2007 11:00 AM
KiNG $h!t
Dec 9, 2004 09:19 PM
