Transmission & Drivetrain Gearboxes, Differentials, Clutches
HELP! Clutch/Tranny may be broken..
Old Jul 15, 2012 | 06:48 PM
AyZyN's Avatar
Default HELP! Clutch/Tranny may be broken..
Car: Honda Civic 97
Motor: Jdm b16a, hydro.
Hey everyone, I would really appreciate the help here. So the story is, I was driving on the freeway, and all of a sudden it popped out of 5th gear (it's not low fluids, did that) and I hear a grinding sound, so I pulled over to the side. I can still shift into 1,2,3 gears fine, but 4th gear is totally locked up and I can't shift into it at all. I can shift into 5th but, if i tried driving on it, it makes a crazy metal grinding noise. I can drive on 1,2,3 gear fine, but there there is a grinding noise when I'm rolling regardless of what gear its in. Any ideas???
Will a clutch kit replacement be the solution? I'm hoping it's not the whole tranny.
Thank you! Any help will be greatly appreciated!
Old Jul 16, 2012 | 06:14 PM
MonkeyMagic's Avatar
Default Re: HELP! Clutch/Tranny may be broken..
you didn't mention reverse. have you looked under the car? it's a long shot.. but maybe something got wedged or bent up and is inhibiting the shifter's motion.
otherwise, there is a good chance something has failed inside your transmission in a curious and unusual manner.
Old Jul 16, 2012 | 06:17 PM
AyZyN's Avatar
Reverse is fine too, I'll check underneath. I had a buddy look at it, and he said it was the tranny. But I'll tell ya whats up after I check it.
Old Jul 16, 2012 | 06:54 PM
if reverse works it's unlikely to be something under the car...
good luck
Old Jul 17, 2012 | 12:04 AM
AyZyN's Avatar
I checked underneath, nothing =/ but here is a video I found of another car that has a tranny that sounds like what I'm experiencing:
http://www.youtube.com/watch?v=_yjdB_XOzh8
Let me know what you think. It's probably the tranny huh
TeamProjectZero
May 7, 2010 06:24 AM
JDM2317
Apr 21, 2010 04:30 PM
2ndgentegracer
Jun 14, 2007 12:23 PM
turboegg6
Aug 9, 2006 02:53 PM
H.A.R.T b16a1crx
Sep 4, 2004 11:07 PM
