P73 ECU Problem In 96 Civic with ITR Engine
Old Jul 15, 2012 | 04:02 PM
k20user's Avatar
Default P73 ECU Problem In 96 Civic with ITR Engine
If my friend can get the ECU working properly he can get his car certified from the state of CA.
So we got a USDM ECU P73-A03 from 98 ITR USDM.
Now when I put the USDM ITR ECU In the 96 Civic with ITR Engine.. the motor starts and dies, the ECU is throwing a Code 14.
With the JDM ITR ECU the car starts fine, runs fine. Right now, I don't have the Crank Position Sensor Hooked up on my JDM Engine, running the USDM ITR ECU.
Just trying to start the car with USDM ITR ECU, engine starts and dies with code 14.
I tried the same USDM ITR ECU In 98 Integra GSR, same problem. Engine starts and dies and code 14. What can be wrong? Any ideas.
http://youtu.be/t5BC96WR7fw
The wiring is proper because the JDM ECU doesn't throw any codes. That is what I have been using for some time now. But this USDM ITR ECU throws a code 14 and engine starts and dies. I tired the USDM ITR ECU in the above 98 GSR, same problem...starts and dies and throws code 14, video posted above..
Please help, thanks in advance!
Old Jul 15, 2012 | 04:05 PM
grumblemarc's Avatar
The Grumpiest
Default Re: P73 ECU Problem In 96 Civic with ITR Engine
I don't see a problem? Why not use the ECU that actually works?
Old Jul 15, 2012 | 04:11 PM
k20user's Avatar
The problem is I want to run the 98 USDM ITR ECU on the 96 Civic.
That is not working. The JDM is working fine but I am trying to help a friend get his civic running with his USDM ITR ECU.
Old Jul 15, 2012 | 04:13 PM
The Grumpiest
Why?
I'm reminded of the saying "If it aint broke, don't fix it".
Old Jul 15, 2012 | 04:14 PM
k20user's Avatar
Why?
Because in CA..the law requires it to get legal swap.
Old Jul 15, 2012 | 04:15 PM
The Grumpiest
I don't see where you even mentioned that IN THE FIRST THREAD.
NBPdEeCeE
Feb 25, 2007 01:34 AM
