ZC rings, rod & main bearings etc. Which ones???
Old Oct 15, 2002 | 09:09 AM
gregv's Avatar
Default ZC rings, rod & main bearings etc. Which ones???
hey guys
I am sure this has been covered here before, but my search came up with too many non-ZC specific answers
to go through. I am planning a rebuild of my '91 ZC (DOHC), and I am in need of some part numbers or Honda
equivalents. I understand that the head gasket is the same as the 88 prelude (2.0i?), and I have already figured
out the crank and cam seals; so which piston rings and rod & main bearings fit??? Are there any ZC only parts
that I will need to find?
any info appreciated
Old Oct 15, 2002 | 11:40 AM
CimorelliCRX's Avatar
Default Re: ZC rings, rod & main bearings etc. Which ones??? (gregv)
Piston rings and rod bearings are from an 89 integra.
Old Oct 15, 2002 | 12:19 PM
keithv's Avatar
here you go:
http://breaka19.netfirms.com/zc/parts_list.htm
[Modified by breaka_1_9, 3:55 PM 10/16/2002]
Old Oct 15, 2002 | 02:22 PM
G-reX's Avatar
Default Re: ZC rings, rod & main bearings etc. Which ones??? (breaka_1_9)
i was just about to ask the same question. And that parts list link didn't work for me.
Old Oct 15, 2002 | 04:20 PM
gregv's Avatar
Default Re: ZC rings, rod & main bearings etc. Which ones??? (G-reX)
thanks for all the info!!
I guess it would be smart to take it apart first and figure out if I am going to need oversize rings, right?
Same for the mains....
thanks again
Old Oct 15, 2002 | 05:08 PM
G-reX's Avatar
I got the link to work but (gregv) do you what rings to use, teg or stock crx?
Old Oct 16, 2002 | 03:39 AM
keithv's Avatar
that is one thing i need to add to the doc....you use stock 88-89 teg piston rings.
Mark Colglazier
Engine Machining & Assembly
Jan 29, 2019 09:12 PM
zenon8890
Jan 6, 2010 07:44 AM
ssbpturbohatch
May 10, 2005 10:18 AM
G-reX
Dec 16, 2002 06:11 PM
travis_118
Mar 24, 2002 12:03 AM
