Transmission & Drivetrain Gearboxes, Differentials, Clutches
what affects clutch pedal travel?
Old Jul 14, 2012 | 06:01 PM
muddmonky's Avatar
Icon2 what affects clutch pedal travel?
what affects how high your clutch pedel is and how far it travels? asuming its properly bleed and has full fluid lvl.
is it the pressure plate or what cause iv been in some ppls cars and there clutch pedal sits lower and travels way less than mine does.
Old Jul 15, 2012 | 01:50 AM
david974's Avatar
Default Re: what affects clutch pedal travel?
the master cylinder has a threaded rod, and you can adjust with the pedal
Old Jul 16, 2012 | 06:17 PM
MonkeyMagic's Avatar
some different clutches will have a different engagement point.
but typically the adjustment rod on the back of the pedal and the stopper on the pedal bracket. a lot of ricers set it so that the engagement point is 2mm off the floor.. why? idk. pain in the *** if you ask me.
Old Jul 18, 2012 | 10:51 AM
muddmonky's Avatar
ya im kinda afraid to mess with the adjustment rod because iv herd so many stories of the clutch never fully disengaging and roasting clutch plates that way.
dcp56
Aug 28, 2018 10:25 AM
vinuneuro
Aug 2, 2007 02:56 PM
LOC714
Sep 23, 2004 12:34 PM
MrSmith
Sep 28, 2001 08:30 PM
