bad alt or bad batt
Old Jul 14, 2012 | 10:45 AM
accordin 2 me's Avatar
Default bad alt or bad batt
Ok this is my second accord in 9 years. My story is that I blew my b2 and replaced it with a low milage b1 but used b2 dizzy harness and ecu. I finally brought the car home today but charged the battery because after five months it was dead. Its under a year old and advanced said its fine and driving home my speakers sounded like **** before the radii just cut off. Next the car wouldn't start back up after I parked. Wtf? I don't have a battery light at all while the car is running and I didn't have the problem before the new motor. Also my alt now whines like a bad dizzy but this is also new. Bad alt with no batt light? Which fuses control it?
Old Jul 14, 2012 | 10:59 AM
lazlong's Avatar
Default Re: bad alt or bad batt
Battery is only there for start up. Alt provides electricity while running. Sounds like the alt went bad and you're only running on battery power. Check all the connections first then have the alt tested.
Old Jul 14, 2012 | 11:07 AM
When it stops raining for more than two minutes I'll jump start the car and pull the neg terminal then check connections
Old Jul 14, 2012 | 11:13 AM
b20c5eg's Avatar
I would cut out any guess work and check for voltage while running. IMO 13.5 and higher and the alternator is good, anything lower than that and it might be ready for a new one. good luck
Old Jul 14, 2012 | 11:26 AM
Lil Gnome's Avatar
Agreed. 12.5v - 12.7v car off, and 13.5v - 13.8v. Check it.
Old Jul 14, 2012 | 11:31 AM
I'll check as soon as the downpour stops
Old Jul 14, 2012 | 11:58 AM
lazlong's Avatar
Rain? What's that?
Old Jul 14, 2012 | 12:44 PM
b20c5eg's Avatar
Originally Posted by lazlong
Rain? What's that?
yea i know the feeling. brown grass everywhere you look.
Old Jul 14, 2012 | 01:06 PM
lol it only rains when i want to accomplish something dealing with one of my cars. besides that its typical florida gulf coast heat. aka 100% humidity daily and 99 degrees plus
Old Jul 14, 2012 | 01:11 PM
gary95H22Accord's Avatar
I don't know what year you have, but if it is your alternator I have one from a 94-97 I can sell you real cheap
Old Jul 14, 2012 | 04:01 PM
its a 95 and I went and got the batt fully charged this time. With my radii and amp off I get 13.6-13.8 but when there on with head lights I get 12.9-13.1
Old Jul 14, 2012 | 04:17 PM
Ok when the amp was on for about five minutes I noticed that the voltage dropped to 12.2 and this time when I pulled the positive terminal off the car cut off. Sooooo is my alt going bad or is it a fuse that's blown and is arching
Old Jul 14, 2012 | 05:18 PM
Hidenplanvew's Avatar
It should be in the 14's if the alt is good.. Sounds like you need a new alt.
Old Jul 14, 2012 | 08:02 PM
doctorbee's Avatar
Alternator is bad. It needs to be able to 1: supply your vehicle's electrical needs 2. charge your battery that you drained when starting the car
When you pulled the battery the alternator couldn't supply enough electricity to power your car and it died. Therefore, your alternator is bad.
Old Jul 15, 2012 | 12:20 AM
nus_dogg's Avatar
Hook it up to a VAT-40 if you really want to know.
Old Jul 15, 2012 | 10:32 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Battery is only there for start up. Alt provides electricity while running.....
That is incorrect....
The voltage drop is too low. The alt is likely junk. I do not recall if there is an alternator fuse, but it wouldn't hurt to check for one before replacing the alternator. Also make sure the drive belt is properly tensioned.
Old Jul 15, 2012 | 12:02 PM
ok last night is the first time i actually drove the car since i noticed the batt was drained.....yup got the batt light (alt) finally so its just time to change it out. thanks guys
Old Jul 16, 2012 | 11:21 AM
oc9979's Avatar
According to the Haynes Repair Manual. The fuse should be #4. I checked it but it does not say alternator. It should be 7.5 volts fuse.
Old Jul 16, 2012 | 11:23 AM
oc9979's Avatar
That should tell you that your alternator is bad.
Old Jul 17, 2012 | 01:40 AM
holmesnmanny's Avatar
New Alt whining = tighten the belt.
ever'sneighborhood
13
Dec 15, 2011 07:46 PM
dividedas1
10
Nov 11, 2008 07:31 AM
chippy
Oct 18, 2005 06:39 PM
my ride
Jul 21, 2004 10:40 PM
Timmay
Feb 27, 2004 04:01 PM
