Rotor "rubs" on back left only when turning.. wtf!!
Old Jul 13, 2012 | 07:20 PM
Vagitarian's Avatar
Default Rotor "rubs" on back left only when turning.. wtf!!
Just got my car back together, all new brakes and bushings in the rear end of both sides, and I went for a shake down run and notice that I get a rotor rbbing noise when going around a turn, at any speed, when the brakes arent applied, and the noise instantly goes away when I straighten out.
Its only coming from the back left but I see now signs of wear and everything is tight
What do you guys think it could be??
Old Jul 14, 2012 | 12:17 AM
Tims Toy 500's Avatar
Default Re: Rotor "rubs" on back left only when turning.. wtf!!
The rotor may not be properly seated. Or - How are your wheel bearings?
Just a thought :-)
Old Jul 14, 2012 | 03:31 AM
TearSDMF89dx's Avatar
could also be rubbing the backing plate
Old Jul 14, 2012 | 04:05 AM
Spug's Avatar
aka, the dust shield
Old Jul 14, 2012 | 05:40 AM
Vagitarian's Avatar
Ill check out the dust shield again, i just cant recreate the noise while spinning the rotors with the car i the air, everything sounds mint, but as soon as you go around a corner.. bam, rubbage
Old Jul 14, 2012 | 06:18 AM
if its rubbing or scraping there should be visible evidence pull the rotor off and look for "bright" spots where metal is hitting metal
Old Jul 14, 2012 | 08:55 AM
Vagitarian's Avatar
dont know how I didnt think of this, but my car doesnt have a backing plate on the rear brakes. I pulled the wheel off just now with the intention of checking the clearance, but there was no plate lol
I took off the caliper and rotor, inspected the pads, everything looked good so I put it all back together.
Took it for a drive and the noise is still present only when turning....
What could it be that would only rub when turning!!
Old Jul 15, 2012 | 06:11 AM
Vagitarian's Avatar
Could my new rotor just be weak and flexing? Its brand new, but its autozone brand
Old Jul 15, 2012 | 06:33 AM
mtflyboy25's Avatar
I dont know man. My rear discs grind/rub too haha. I havent been able to figure it out!
Old Jul 15, 2012 | 10:33 AM
Vagitarian's Avatar
bearing possibly?? I feel no play in the wheel with the car on the ground, didnt check with it in there air
I dont get why it makes this noise
Old Jul 15, 2012 | 10:47 AM
mtflyboy25's Avatar
no idea... could be. i will find out though eventually haha.
Old Jul 16, 2012 | 03:55 AM
could definitely be a bad wheel bearing sometimes when they initially start to fail you cant feel the play without a load on them ...also check your torque on the bearing if not properly torqued it can effect bearing preload and could cause the symptom you're describing
Old Jul 16, 2012 | 05:28 AM
Vagitarian's Avatar
how would I check the torque on the bearing? I dont quite know how to get to it, after I take the caliper and rotor off what do I do from there?
I almost wanna just change the hub/bearing whatever I need to to fix this problem, its super annoying and I need this car to be reliable
Old Jul 16, 2012 | 05:35 AM
mtflyboy25's Avatar
Yeah what part needs torqued.... I dont have my car and cant quite picture it....
Old Jul 16, 2012 | 06:02 AM
take the wheel off remove the dust cap at hub center then torque the spindle nut to proper torque....reassemble and test drive
Old Jul 16, 2012 | 07:27 AM
Vagitarian's Avatar
Ill dig up what torque the nut should be at
Would LOVE if that was the only problem
Old Jul 16, 2012 | 08:38 AM
xxOldschoolxx's Avatar
Try tAking off the rear tire and spinning the hub. If there is any grinding noise it might be time to change. Compare to the opposite side to get a better feel if it is faulty.
Old Jul 16, 2012 | 02:26 PM
Vagitarian's Avatar
The hub spins like new, freely and noise free
Old Jul 16, 2012 | 02:48 PM
DumpdEJ6's Avatar
I like the tuna here
Sorcery, I say. Pissed off any witches or wizards lately?
Old Jul 16, 2012 | 03:01 PM
phunhaus's Avatar
Take the small dust cap off the center of the hub/bearing assembly and torque the nut - #41 in the above picture.
I will also agree that it sounds like a wheel bearing issue. Either an improperly seated assembly or excessive play. But if there was excessive play you should hear a low grumbling noise from that wheel most, if not all, of the time. With the wheel on the car and the weight off (in the air) press and pull on the top and bottom of the wheel. If it rocks back and forth your bearing is more than likely bad and should be replaced.
Old Jul 16, 2012 | 03:11 PM
Vagitarian's Avatar
what should the bearing be torqued to?
Old Jul 17, 2012 | 08:56 AM
phunhaus's Avatar
Google. I have no idea.
Old Jul 17, 2012 | 09:11 PM
Je2RiT's Avatar
Had this problem before. It was actually my caliper mounting bolts.
Take a flashlight and look between the back of the rotor and where mounting
Holes are. If you see any portion of the bolt you need to add a washer or a couple
So it doesnt rub when you turn.
Old Jul 18, 2012 | 10:20 AM
Vagitarian's Avatar
Caliper bolts are seated properly, verified that after your post again though. The wheel spins fine and free when in the air, no rotor contact at all, just going around a left turn it kisses it and drives me crazy
Old Jul 19, 2012 | 03:48 AM
Vagitarian's Avatar
yes, a lock washer on each
