want to do a swap need some info on it
I believe the h23 is an external coil so you're gonna need to get an internal coil distributor for an h22a which is the same. It is called the td-60u on ebay.
The h23 also has a knock sensor so you will need to add a knock sensor wire. And obviously you will need an h23a ecu.
You can use either your own tranny or the h23a tranny with the h23 engine.
just leave the block in the car, put the h23 head on it, with an f23 head gasket, and change the water and oil lines, and block the 2 oil ports or drill them a little bit, the dizzy is external i think as well. everything else matches up even the manifolds and exhaust
use the h23 tranny, i think its the same length but ive heard it is much stronger!
The H23 has different gearing than the F22. It's not too short but not too long. It's the middle of the road between the H22 and F22 transmissions. They are the same strength.
rhdune16
Jan 1, 2006 02:51 PM
