ef mini me overheating
Old Jul 13, 2012 | 04:10 PM
m3kid's Avatar
Default ef mini me overheating
i got my mini me running but some how when i was pouring water in it look like some oil mix water or brownish didnt think much and some how it keeps overheating i have to keep pouring water the thermostat is not sticking these no water my oil so that rules out head gasket it may be leaking im not sure from where no smoke comes from the engine bay so i cant see where the leak is coming from. Im going to check on the fuel pump maybe that could have a leak but it was running fine when it was dpfi.
Old Jul 13, 2012 | 05:11 PM
grumblemarc's Avatar
The Grumpiest
Default Re: ef mini me overheating
Headgasket.
Water doesn't have to be in the oil for it to be a headgasket. If you reused the stock headstuds I can guarantee you it's the gasket.
Old Jul 13, 2012 | 06:40 PM
m3kid's Avatar
yea thats what my mechanic said i guess i will need to get arp head studs and a new head gasket and ohh im using a y8 head gasket to bump the compression. But why would the old head studs cause it to be the head gasket.
Old Jul 14, 2012 | 03:22 AM
The Grumpiest
OEM headstuds are one use only.
Old Jul 14, 2012 | 05:55 AM
m3kid's Avatar
dam all the mini me write ups said to re-use the old head bolts. And where is all that coolant going too? ot doesnt smoke or nothing it just keeps heating up and seems to be eating up all the water.
Old Jul 14, 2012 | 05:58 AM
The Grumpiest
If it's not leaking it then it's being burned. If you can get a look at your piston tops, see if they are pretty clean.
Old Jul 14, 2012 | 07:16 AM
m3kid's Avatar
i can see where it leaks from ill see if i can see if it leaks but if its burning it shouldnt it be smoking?
Old Jul 14, 2012 | 09:53 AM
The Grumpiest
Not really. That would be extreme. My hatch with a bad headgasket burned coolant and never smoked. As you can see headgaskets do not have a set bunch of systems.
Old Jul 14, 2012 | 12:45 PM
m3kid's Avatar
yea i cant see where it leaks i guess its the headgasket then thanks
m3kid's Avatar
and new head bolts
Old Jul 14, 2012 | 03:37 PM
The Grumpiest
You should do compression and leakdown tests on the engine.
Old Jul 14, 2012 | 07:37 PM
m3kid's Avatar
got 180 across the board also switch over some coolant lines some where in the place plugged 2 coolant lines that where leaking and wired my fan to a switch lol the temp stayed below the middle also when i first put coolant in it looked like oil mixed with water came out the radiator but i drained and it was good afterwards so i think it isnt my headgasket and doesnt overheat no more
Old Jul 15, 2012 | 03:12 AM
The Grumpiest
Excellent.
Old Jul 15, 2012 | 08:15 AM
m3kid's Avatar
yea but im still getting a little leak behind the intake or somewhere there causing my radiator coolant to drain not a big leak but you can tell it leaks. Any suggestions?
Old Jul 15, 2012 | 08:32 AM
The Grumpiest
You have to find the source of the leak. That's it.
shocker911
May 30, 2011 05:19 PM
jdmboy96
18
Sep 3, 2009 08:51 PM
mastakmk
May 5, 2008 10:53 AM
hondaboyz94si
Dec 10, 2005 06:13 PM
JTCdudeman
Sep 29, 2005 05:42 AM
