Compiling a list for a "junkyard turbo"
So far:
T25 turbo from 96 mitsubishi GS-T
all the charge piping, air filter..
what manifold is cheapest? or can i make one out of a header ?
downpipe
i know I SHOULD have a BOV, but i am trying to get the bare minimum to run like 5psi on a b16a2, just a turbo..period. I will upgrade as I go.
thanks for ANY input..
thanks,
mike
downpipe
thanks,
mike
You can get a manifold from thedropshop.tv for around 200 to 300 bucks. Or try to find a used one. Headers are too thin to make turbo manifolds out of usually. Grab the injectors, bov and intercooler from that gs-t. Buy a fuel controller too. Don't try to run without one 'temporaily' because you might break something.
[Modified by mos, 9:40 AM 10/15/2002]
is re-wiring the injectors pretty easy then? like positive/negative/ground sorta thing?
how much do u think this setup would run total?
i am hoping pretty cheap.
thanks,
mike
thanks,
mike
Check out my site in the sig.
Dropshop has the cheapest log manifold.
Make the downpipe yourself.
5 psi still needs a BOV. Get the Bosch one for $45.
See my parts list for locations to buy stuff.
Randy
Randy
if you gonna spend money on a bov try and find a 1g dsm bov, you should be able to find one for under $50 and they are much better then the napa ones or the 2g dsm's
i am in Eau Claire for schoo...
how about u? where in MN? i lived in MN until i was 11, so im very familiar with it!
srg
Apr 25, 2006 07:37 PM
TwoPointZero
Jul 12, 2004 09:14 PM
mamaboy
May 19, 2004 01:17 PM
tegasaurus
Jan 8, 2004 08:01 AM
pdiddyparsons
Apr 3, 2003 05:01 PM
