Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
▐▐▐▐▐ Hondata S300 V2's!! Kpro's, Flashpro's, Reflashes and Map sensors!!▐▐▐▐▐
Old Jul 13, 2012 | 09:25 AM
ChrisMillerRacing's Avatar
Default ▐▐▐▐▐ Hondata S300 V2's!! Kpro's, Flashpro's, Reflashes and Map sensors!!▐▐▐▐▐
S300
The s300 is a plug in module to the OBD1 factory Honda Engine Computer (ECU) which vastly expands the capabilities of the factory ECU. Forced induction, datalogging, real time updating of parameters, engine protection are but a few of the s300 features.
Note that there is a rectangular frame ECU version of the s300 and a square frame ECU version (s300J)
s300/s300j Overview
s300/s300j Price, availability and Options
*(all S300 purchases from us include a base map done by Chris Miller scaled to your injector size, map sensor and ignition system. This map is not to be driven under heavy load or boost)
Price Description
$490 shipped s300/s300j with all features and software
$395 shipped back to you upgrade from staged system/s100/s200 to s300/s300j with all features and software (use this form)
$250 shipped back to you upgrade from old s300 to new s300 V2
If you need your S300 installed, you can ship us your P28 or P72 OBD1 ecu and we will install it for FREE with your purchase.
Features
New features for Version 2:
8 analog inputs.(datalogging only)
1 digital input. (datalogging only)
Additional security to help identify and prevent theft
Datalogging memory doubled in size for up to 2 hours recording.
Non battery memory backup for greater reliability and longer life.
On board calibration storage.
Main features:
Fits inside the ECU
USB connection for speed and compatibility
SManager Windows based software for parameter & table editing, calibration uploading and datalogging.
Real-time updating of ECU parameters & tables.
Built in calibrations for common engine combinations
Built in datalogging to a laptop
On board datalogging memory (8 MB memory, 20-240 minutes datalogging) with trigger conditions.
Adjustment for different sized injectors, with overall fuel trim.
Configurable for any MAP sensor (to at 5 Bar and above)
TPS based table lookup for ITBs
Engine protection from over boost.
Expanded fuel and ignition tables, both in rpm and load, to 60 lbs boost and 11,000 rpm (these are not the upper limits)
Launch control with anti-lag
Full throttle shift
Three multi purpose outputs for nitrous control or similar
Supports lambda tracing from a wideband o2 (PLX wideband recommended)
PWM output for boost control with fixed or gear based boost.
Dual tables for high/low octane calibrations etc.
Two analog inputs for wideband, EGTs etc.
High and low speed 24 x 20 ignition and fuel tables for correct VTEC tuning
Injector size fuel trim
Fuel trim for starting, throttle tip in and individual cylinder trim
Rev limiter with fuel cut or fuel and ignition cut
Full throttle shift
Adjustable VTEC window with load and throttle control
Secondary intake runner control
Adjustable idle speed
Adjustable boost cut with hot and cold settings
Shift light
Closed loop control
Air temperature compensation
Water temperature compensation
Fuel and ignition correction based on gear
A/C shutoff conditions
Closed loop
Three general purpose outputs for nitrous control, quad boost control or similar
KPRO
ALL KPRO'S COME WITH FREE BASE MAP by Chris Miller scaled to your map sensor, injector size and ignition setup. This is a map so you can get your car running if need be but only for that, not to be driven on under boost or heavy load.
The K-Series Programmable ECU (K-Pro) consists of a hardware modification to any K-Series ECU, plus Windows software which allows you to re-program the ECU and datalog sensors.
On-board datalogging is now standard on all K-Pros from serial number 4111 and above. For more information go here.
Applications/Prices
Acura RSX/ Honda Integra
2002-2004 RSX (Type S) (PRB ECU)
2002-2004 RSX (Base 5 speed) (PND ECU)
2001-2006 Japanese DC5 Integra Type R (PRC ECU)
Price Description
$500 Upgrade cost for existing Hondata reflash prior to March 22 2010 (ECU must be sent to Hondata or authorized installer).
$800 Upgrade cost for existing Hondata reflash after March 22 2010 (ECU must be sent to Hondata or authorized installer).
$990 Retail price (ECU must be sent to Hondata or authorized installer).
2005-2006 RSX (manual transmission with adapter harness and modified 02-04 ecu and O2 sensor)
Price Description
$250 Upgrade an already K-Pro'd ecu for use in an 05-06 RSX (includes adapter harness and ecu modification)
$1190 K-Pro for 2005-2006 RSX includes adapter harness.
Honda Civic
2001-2005 Civic (DX, LX, HX & EX Manual transmission only D17 engine )
2002-2005 Civic Si (PNF ECU)
2003-2004 Japanese Civic Type R (PRD ECU)
2002-2005 Euro CivicType R (PRA ECU) Contact your European dealer for prices
Price Description
$950 Retail price (ECU must be sent to Hondata or authorized installer).
$180 Hondata specific D17 cam gear for those who already have a K-Pro
$1125 D17 K-Pro installed in a customer supplied donor ECU with Hondata cam gear
Honda S2000
2000-2005 S2000 (built in adapter harness, requires some modifications to sensors)
$1295 00-05 S2000 K-Pro in a user supplied PRB ECU with wiring harness and bracket.
$450 00-05 To convert an existing K-Pro and ECU to S2000 K-Pro with wiring harness and bracket.
*2006-2009 S2000 Dual adapter harness. Discontinued. Replaced by FlashPro.
Honda Element
2003-2006 Element (manual transmission with adapter harness and modified 02-04 ecu)
Price Description
$250 Upgrade an already K-Pro'd ecu for use in an 03-06 Element (includes adapter harness and ecu modification)
$1095 K-Pro for 2003-2006 Element includes adapter harness.
Others
Engine Swaps - Must use 02-04 Engine harness and 02-04 Transmission
Price Description
$950 (ECU must be sent to Hondata)
For the Lotus Elise and Exige a dash converter is available.
Features
Main features:
Fits inside the ECU
Designed and assembled in USA
KManager Windows based software for parameter & table editing, calibration uploading and datalogging.
Many built in calibrations for common engine combinations
On board datalogging memory (2 MB memory, 10-110 minutes datalogging)
Configurable for any MAP sensor (to 5 Bar and above)
Engine protection from over boost and lean protection.
Supports lambda tracing from the stock wideband o2
KManager editing software features:
High and low speed 16 x 20 ignition and fuel tables for correct VTEC tuning
MAP sensor type and calibration
Closed loop control
Closed loop
On board datalogging trigger conditions
Flash Pro
The FlashPro allows full user tuning and datalogging of late model performance Hondas and Acuras. It includes Windows based software called FlashProManager.
The FlashPro connects from your laptop's USB port to your vehicles diagnostic port to provide live tuning with a variety of calibrations, extensive real time and stored datalogging capabilities.
Vehicle FlashPro Part Number Price
Civic
2006-2011 US Civic Si FP-SI-US $690 shipped
2006-2011 US 1.8 Civic FP-R18-US $690 shipped
2006+ Mexico Civic Si FP-SI-US $690 shipped
2007+ Central American Civic Si FP-SI-US $690 shipped
S2000
2006-2009 US S2000 FP-S2K-US $690 shipped
2006-2009 Asia S2000 FP-S2K-INT $690 shipped
2006-2009 Europe S2000 FP-S2K-INT $690 shipped
TSX
2007-2010 US TSX FP-TSX $690 shipped
CR-Z
2010+ US CR-Z (MT & CVT) FP-CRZ-US $690 shipped
2010+ Euro CR-Z FP-CRZ-INT $690 shipped
2010+ Japan CR-Z (MT & CVT) FP-CRZ-INT $690 shipped
Map Sensors
The Hondata 4 bar map sensor is a plug compatible replacement for the Honda factory MAP sensor. 4 bar MAP sensors offer true plug and play with an OEM look. Each sensor can read up to 44.1 PSI (3 bar above atmosphere). It is a direct replacement for the B, D, H, F and K-series Honda engines. This plug in sensor takes less than 60 seconds to install and eliminates the risk of sensor damage that often occurs when attempting to wire in other types of MAP sensors.
Price is $95 shipped anywhere in 48 states!!
Paypal is accepted and you can go ahead and just send $95 to Sales@GetPowerHouse.com and we will get it right out.
B series
K series
06+ S2k and R18 civic
Old Jul 16, 2012 | 08:34 PM
Default Re: ▐▐▐▐▐ Hondata S300 V2's!! Kpro's, Flashpro's, Reflashes and Map sensors!!▐▐▐▐▐
Please call 631 465 0988 or e-mail us at Sales@GetPowerhouse.com to order!!
Old Jul 27, 2012 | 07:28 AM
Old Jul 30, 2012 | 09:54 AM
Old Aug 7, 2012 | 09:51 AM
Old Aug 15, 2012 | 11:46 AM
Old Aug 20, 2012 | 11:47 AM
Old Aug 22, 2012 | 01:18 PM
Old Aug 24, 2012 | 01:10 PM
Old Aug 27, 2012 | 12:34 PM
Old Sep 5, 2012 | 07:35 AM
Old Sep 10, 2012 | 01:35 PM
Old Sep 12, 2012 | 10:46 AM
Old Sep 17, 2012 | 02:03 PM
Old Sep 21, 2012 | 06:32 AM
Old Sep 24, 2012 | 01:33 PM
Old Sep 28, 2012 | 11:48 AM
Old Oct 2, 2012 | 09:46 AM
to the top!!!
Old Oct 5, 2012 | 10:55 AM
Old Oct 10, 2012 | 10:40 AM
Old Oct 26, 2012 | 01:44 PM
Old Nov 8, 2012 | 12:24 PM
Old Nov 16, 2012 | 08:16 AM
Old Nov 27, 2012 | 10:57 AM
Old Dec 7, 2012 | 09:03 AM
