uninstalling vigor front bumper
hey, can anybody help me take off the front bumper from a 92 acura vigor? I can't seem to get to the two screws right under the headlight....any help is appreciated....thanks
There are two bolts by the headlights inside the engine compartment.
The passenger side you have to remove some things to get to.
The driver's side lift up the overflow for the coolant and you should see the bolt.
18 or 19mm bolts, I can't remember.
On driver side you can see it once you remove the overflow coolant container.
It is at the very bottom.
The passenger side you have to take some things out to get to the bolt.
Once you have those two bolts off, you need to unclip the bumper at the wheel wheel and it will come out.
