My 95 Civic Si getting a HEART TRANSPLANT
Old Jul 11, 2012 | 08:37 PM
FRIEDRiiCE924's Avatar
Default "Feleray Drempt" memorial build/restoration
So to start this off my name is Julian and just recently got stationed in Hurlburt Field, FL. Ive had my hatch for about 3 years now and 2 years of having it its probably sat in my garage. I purchased it from a old couple for about $2,500 and it was "MINT" pics.............
***Im going to be skipping alot so I can get to the build but if you want to see the process of what went on between getting the car and the current surgery its under going let me know.
After about a year I replaced it with a complete OEM built D16z6 along with some bolt-ons.
The motor was babied as it was my DD to school and work but I wanted more so I did a B18c GsR swap I got from a good friend.
This is also how the car sat just before going under the knife except...
New Fenders
New Hood
All trim pieces painted with OEM black trim paint
(I have pics of the process just let me know if interested in seeing)
Ok now for the build process....
Out with the old
My buddy Allen got a new camera and went picture crazy!
Shes OUT!
Just waiting for the new heart
Now for the build NA Lsv
Start off with the head
  • My original JDM GSR head
  1. Port and polished
  2. 3-Angle valve job
  3. Port matched
*Machine work credit goes to USA machine.
Valve cover eye candy once the head is assembled
*Airbrush credit goes to Orlando Di
  • Goodies for the head
  1. Skunk2 PRo II cams and complete valvetrain
  2. ARP head studs
  • Fuel
  1. AEM FPR (BWR FPR guage)
  2. AEM fuel rail
  3. Bosch CCT 550cc injectors
  4. 255 Walbro fuel pump kit
All put together
  • Your typical bolt ons
  1. PLM Toda rep header
  2. PLM test pipe
  3. Skunk2 intake manifold
  4. Skunk2 70mm throttlebody
  5. PWJDM intake (Flashy) so switching it out to AEM cold air intake
  6. Greddy spectrum elite full 2.5" exhaust
Now the block
  • Ls block bored to 85mm and AEBs sleeved
*Was told it was a 84mm bore ended getting pistons at 84mm only to find out it was actually a 85mm bore so having to see if Realstreetperformance will switch them out for me for a set of 85mm.
**Once again went with USA machine to get block decked, honed, hot tanked, crank micro polished and balanced just waiting to get it back.
Block goodies
  1. Wiesco 84mm 11:5.1 pistons (switching to 85mm)
  2. Eagle rods with ARP conneting bolts
  3. Clevite full racing bearings
  4. ARP bolts
  5. Oil cooler from my GSR
S80 LSD transmission
Need to order
  • Toda timing belt
  • OEM water pump
  • OEM oil pump
  • OEM valve cover gasket kit
  • Skunk2 throttlebody gasket
  • Hondata thermal intake manifold gasket
  • Cometic 85mm head gasket
  • Clutch
  • Energy shifter bushings
  • Throwout bearing
Ill update when possible.....
Old Jul 12, 2012 | 12:02 AM
92civiceg9gsr's Avatar
Default Re: My 95 Civic Si getting a HEART TRANSPLANT
Nice parts! That hatch looks rather clean too btw.
Old Jul 12, 2012 | 08:28 AM
eg4b18c's Avatar
Looking good! Subscribed for more.
Old Jul 12, 2012 | 11:32 AM
C2K_TB_TEC's Avatar
Awsome! looking forward to this!
Old Jul 12, 2012 | 07:26 PM
Basik_One's Avatar
Hatch and engine look to be a great combination, good luck with the build
Old Jul 12, 2012 | 07:56 PM
Thanks its still got along ways from where I want it.
Thanks alot in store for this build.
Thanks me too.
Thanks
Old Jul 14, 2012 | 06:03 PM
fabioso's Avatar
that car looks fresh, sweet deal on such a mint car.
Old Aug 26, 2012 | 02:40 PM
Got some parts ordered............
New set of Wiesco pistons 85mm 11.5:1
New Type R water pump
New Type R oil pump
New Supertech valve stem seals
New Gates timing belt
New Stage 4 Competition clutch
New Skunk2 cam seal
New Energy shifter bushings
New Cometic 85mm head gasket
New Hondata thermal intake manifold gasket
New ARP flywheel bolts
Still need to get from acura
Oil pan gasket
valve cover set
timing belt tensioner
Should be putting all together in about a week or two pics soon.
Old Aug 26, 2012 | 04:26 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Welcome to the Coast!!! Nice Hatch! Are you on any of the local forums yet? race850dotcom
Old Aug 27, 2012 | 12:54 PM
Thanx and no I'm not actually.
Package of goodies arrived today =]
Old Aug 27, 2012 | 07:44 PM
Ordered HONDATA S300 =]
Old Aug 27, 2012 | 08:02 PM
B20vEf9's Avatar
Build is looking Great!
<< Dan from YCU
Old Aug 27, 2012 | 08:27 PM
Gold DA9's Avatar
looking good.
Old Aug 27, 2012 | 08:47 PM
Dope-B's Avatar
I want to see this after. That is going to be sick!
Old Sep 1, 2012 | 03:02 PM
macDelli's Avatar
Originally Posted by Gold DA9
looking good.
Old Sep 1, 2012 | 03:23 PM
Well visited home and decided to mess with the hatch a little bit.....
Dyed carpet black
Purchased a set of mint recaros
Pics......
Ill start off with the recaros I picked up today for a hell of a price.
All they needed was a good steam cleaning =]
Carpet process
4 x bottles of Rit dye
2 x bottles of scotch guard
1 x bottle of uv protectant
1 x tub
1 x gloves
Filling tub with "HOT" water
mixed dye while being filled
Carpet pulled
Carpet put in tub scrubed for 30mins
Put some weights on top to keep carpet submerged letting set for 4hrs
Old Sep 1, 2012 | 03:31 PM
The Hire's Avatar
Haha @ Afro Samurai... Diggen it!
Old Sep 1, 2012 | 03:48 PM
lol something different came out really good.
Old Sep 3, 2012 | 06:48 AM
Old Sep 3, 2012 | 11:21 AM
97accordbuildlx's Avatar
pffff......... that interiors lookin dope
Old Sep 3, 2012 | 12:09 PM
Brice.Hayden's Avatar
why not an OEM timing belt? everything looks good, i have buddies that fly AC130s and U-28s down at the Hurb.
Old Sep 4, 2012 | 06:30 AM
Thanks I'm about to get mint itr rears
After some research it was between Gates or OEM and the company I get all my parts from deals with Gates so went with there belt.
Old Sep 5, 2012 | 03:20 PM
Ordered
BWR subframebrace
Racequip 5-point harnesses
Old Sep 12, 2012 | 01:32 PM
Just put a order through with DownStar
Bolt Boys B-Series Engine Kit
Add Oil & Water Pump Hardware?: Yes version: Premium Kit
Trans To Bellhousing Kit
Select your transmission: B-Series Select your washer: Standard
Trans To Engine Bolts Kits
Select your transmission: B-Series Select your washers: Standard
Bolt Boys Post To Motor Kit
Select your engine: B-Series
Bolt Boys Starter Bolt Kit
Bolt Boys Mount To Subframe
Bolt Boys Mount To Trans
Select your version: No Stud Select your washers: Standard
Bolt Boys Motor Mount Bolt Kit
Bolt Boys V.1 Hardware
Select your finish: Blue
Old Sep 21, 2012 | 07:10 PM
Box came in......
Hasport mounts
BWR subframe
Racequip harnesses
Bolt boys nuts and bolts
