Complete Single Cam Turbo Swap F/S
Old Jul 11, 2012 | 06:23 PM
Andrew3379's Avatar
Default Complete Single Cam Turbo Swap F/S
i have a full single cam turbo swap forsale everything is legit and there is tons of extras! full edelbrock performer x turbo kit A/C and P/S compatible. Perfect for a stock motor or if your looking to make some power for a fun street car. Kit is capable of holding up to 18psi and 350hp. It is a full swap head is fresh with brand new OEM valve seals purchased from honda and the head has been decked. have reciepts for everything purchased from honda, everything on swap has been ran for less than 100 miles just spent time on dyno. Only downfall is the block has a hole in it due to throwing a rod through it,you just need a new block and bolt everything up dont feel like getting anpother block and dealing with boost anymore looking to start an all motor build any questions feel free to ask PM me or text for info 845 421 2951 any reasonable offer wont be refused as you can see there is alot of money and extra parts into this swap please dont low ball and keep negative comments to self will get the serial number as soon as i get to my tuners shop
OEM Parts,
timing belt
water pump
tensioner
valve cover gasket
valve cover bolts
Thermostat
Valve seals
Aftermarket/Custom Parts,
Brand new inner cooler pipes welded and custom fitted for kit and engine bay
Brand new down pipe custom 5 bolt to vband 3inch to 2 1/2in heat wrapped
Go-Autoworks black box eliminator kit so the line that runs from the catch can will run to the back of the block so you dont need to ever empty the catch can.
custom oil feed line with a -63 oil reducer for the turbo
Catch can with custom black high heat fabric oil lines
Powder coated valve cover
Powder coated intake manifold (starting to peel a little bit)
650 deka injectors
JHPUSA Rad Hoses
HKS SSQ Bov (black)
Garrett GT28 turbo with no shaft play
Edelbrock Intake manifold
Edelbrock front mount
AEM Digital Boost gauge
ACT Stage 2 clutch
Competion 12lb flywheel
OEM linkage with energy suspension bushings
ARP headstuds
Stock axels
AEM Fuel rail
BnM Fuel pressure regulator
NGK spark plug wires
Andrew3379's Avatar
Default Re: Complete Single Cam Turbo Swap F/S
bump it uppp no reasonable offer refused
Old Jul 12, 2012 | 06:52 AM
Andrew3379's Avatar
Bump it uppp
Old Jul 12, 2012 | 08:41 AM
C-Rex1021's Avatar
What year Civic was this setup in?
How did you throw a rod? Old Block? Boost spike? Vacuum line blow off?
Old Jul 12, 2012 | 08:55 AM
OoAoO's Avatar
bumppppppp
Old Jul 12, 2012 | 11:12 AM
Andrew3379's Avatar
It was an old block it was warped I never had it decked after I had the head gasket blow the rod just have out no boost leaks or anything like that was tuned on stock map sensor 10.5 lbs of boost
Old Jul 12, 2012 | 03:24 PM
Andrew3379's Avatar
Bump it upppppp
Old Jul 12, 2012 | 05:03 PM
Andrew3379's Avatar
Bumpppppppppp
Old Jul 13, 2012 | 06:22 AM
Andrew3379's Avatar
Bump it uppp
Old Jul 13, 2012 | 08:59 AM
Andrew3379's Avatar
Bump it upppp
Old Jul 13, 2012 | 12:03 PM
Andrew3379's Avatar
Bump it upppp
Old Jul 14, 2012 | 08:20 AM
Andrew3379's Avatar
Bump it upppp
Old Jul 14, 2012 | 08:21 AM
Andrew3379's Avatar
Bump it uppppp
Old Jul 14, 2012 | 10:23 AM
Andrew3379's Avatar
Bump it tttt
Old Jul 15, 2012 | 04:12 PM
Andrew3379's Avatar
Bump itbupppp
Old Jul 17, 2012 | 06:39 AM
Andrew3379's Avatar
Legit parts someone buy this
Old Jul 17, 2012 | 04:23 PM
Andrew3379's Avatar
Bump it uppp
Old Jul 18, 2012 | 04:25 AM
Andrew3379's Avatar
Bump ittttttttt
Old Jul 18, 2012 | 10:36 AM
Andrew3379's Avatar
Bump it uppp
Old Jul 18, 2012 | 01:55 PM
Andrew3379's Avatar
Someone buy this
Old Jul 20, 2012 | 08:17 AM
Andrew3379's Avatar
Bump it ppppp
Old Jul 20, 2012 | 09:19 AM
luvmihatch's Avatar
Damn 100 miles and you threw a rod. Who tuned it?
Old Jul 20, 2012 | 03:40 PM
Andrew3379's Avatar
Nooooooo lol has not even 100 miles on the new parts lol block had 90k on it
Old Jul 20, 2012 | 10:28 PM
luvmihatch's Avatar
So you got it tuned then 100 miles later it threw a rod?
Old Jul 21, 2012 | 05:16 AM
goldhatch94's Avatar
how much for the manifold turbo and down pipe?
