Started smoking alot 95/f23a1 and possible bad motor mount
Old Jul 11, 2012 | 12:41 PM
krc91987's Avatar
Default Started smoking alot 95/f23a1 and possible bad motor mount
The other day one of my co workers noticed that my car was smoking alot, seemed to be bluish white, we suspected the head gasket, but there is no oil in the coolant or vice versa, oil was low by 1.5qts, now it smokes a little at idle and alot when you accelerate hard, what else could it be?
Also I think my rear motor mount is bad, car shakes when at certain speeds, and when trying to shift into 4th sometimes 3rd, and tranny doesn't like to downshift, I know its not tires, I work at a tire shop, and all the suspension bushings seem to be ok, also at say 25-50% throttle there is a weird squeaking noise dont know if its related, thanks everyone
Old Jul 18, 2012 | 06:34 AM
krc91987's Avatar
Default Re: Started smoking alot 95/f23a1 and possible bad motor mount
bump
Old Jul 18, 2012 | 12:43 PM
1911Man's Avatar
Worn rings, carbon deposits on your valves, something like that. You're getting oil on the combustion side of the piston. If it's bluish smoke, it's not water. If you get the heads done, change the rings too. Repairing the valves causes a compression increase that can cause your rings to start letting oil seep by.
96delsol123
Apr 7, 2013 06:17 PM
averyvm
Jul 26, 2006 12:56 PM
one slow coupe
Jan 31, 2006 06:24 AM
mrbsponge
Aug 22, 2004 07:53 PM
aracer69
Nov 21, 2003 11:09 PM
