Y7/y8 minime
Old Jul 9, 2012 | 04:21 PM
franki16's Avatar
Default Y7/y8 minime
Hi everybody,
i am new on this forum and i start build a mini-me swap (Y7 block and P2E piston / Y8 vtec head) and i would like to put a stage 1 or 2 camshaft in the Y8 head. But i know that the Y7 piston head notches are not as deep as the Y8. Do anybody have done this setup and know if its possible to do, or the valve clearance not good and the piston will hit the valve.
thanks for youre answer and tips
Old Jul 9, 2012 | 06:02 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Y7/y8 minime
Camshaft for what?
And you're in the wrong section.
Old Jul 10, 2012 | 03:44 AM
franki16's Avatar
how do i move this topic in the performance one ?
Old Jul 10, 2012 | 04:11 AM
The Grumpiest
So what is a cam supposed to do for you?
Old Jul 10, 2012 | 05:59 AM
nealnanoHX's Avatar
Yeah what are your goals for the mini me set up? You are not going to get much out of a cam with that compression.
Old Jul 10, 2012 | 08:32 AM
franki16's Avatar
my goals is like 140 -150 hp from my D16 mini-me setup and want to stay N/A
Old Jul 10, 2012 | 08:46 AM
The Grumpiest
From a cam? Better go read up in the All Motor section and see what it actually takes. This isn't a big V8 where you can slap on a cam, do nothing to tune it, and make 30hp. Stop watching the Speed Channel.
Old Jul 10, 2012 | 02:49 PM
nealnanoHX's Avatar
140-150whp not with that compression on a D series.
Old Jul 11, 2012 | 03:57 AM
franki16's Avatar
not 150 whp but 150 HP at the flywheels i would like to. And i know that i will not have 150hp just by drop a camshaft inside this head. The setup i'd like to have a the end is to have a Skunk2 intake manifold with a 65mm throttle body, light port and polish, 2 1/4 inches exhaust headers + cat-back exhaust AND a camshaft exhaust + Throttle coolant line bypass and intake manifold head shield gasket. Not to dificult if you know that with the d16y7/d16y8 i should to be close to a Ex civic (127hp)
Old Jul 11, 2012 | 04:04 AM
The Grumpiest
??? What's a camshaft exhaust? Still don't think you'll make it.
Old Jul 12, 2012 | 06:07 AM
franki16's Avatar
sorry for the mistake. i was want to say a Skunk2 intake manifold + a 65mm throttle body, light port and polish + 2 1/4 inches exhaust headers + cat-back exhaust AND a stage 1 or 2 camshaft + Throttle coolant line bypass + intake manifold head shield gasket.
Old Jul 12, 2012 | 07:10 AM
The Grumpiest
Nope. Won't get close. Without a tune that manifold will have you running like crap.
uindaway
Nov 2, 2012 09:42 AM
z6dxej1
Apr 24, 2012 10:19 PM
TehMoonRulz
May 30, 2005 08:51 AM
Evolution-93-Ex
13
Oct 3, 2004 01:31 PM
tai93si
Jan 16, 2004 07:36 AM
