? about b18c1 into ef si
Old Jul 8, 2012 | 09:56 PM
skill178's Avatar
Default ? about b18c1 into ef si
Alright, I'm not asking how to swap, there's a lot of right ups for that, what I need to know is what do I need to do to the wiring harness? I got the ecu and dizzy jumpers for obd0 to obd1 but will the d series to b series have a different pin out? (will my injector eires be plugged up to my horn?) Lol, I know to wire in vtec and the sensors I dont got on the ef, but will all my current plugs be the same?
Old Jul 9, 2012 | 01:27 AM
villc713's Avatar
Default Re: ? about b18c1 into ef si
Yes plug and play most of them
Old Jul 9, 2012 | 05:56 AM
skill178's Avatar
Great to know, thanks.
Old Jul 9, 2012 | 05:59 AM
91 EF DX's Avatar
Injector plugs may need to be swapped out depending on if you use obd 0 or obd 1 injectors. If you use obd 1 injectors you have to delete the resistor box also.
Old Jul 9, 2012 | 06:52 AM
omiehomie's Avatar
you sure thats for obd1 and not obd2?
on my 99 gsr (obd2a) when i put OBD1 injectors in for boost i had and current am running a resistor box?
can you shed some light on why obd1 injectors dont need a resistor box?
Old Jul 9, 2012 | 07:13 AM
91 EF DX's Avatar
hmm didn't know you could do that. cool
Old Jul 9, 2012 | 07:17 AM
mike-y's Avatar
I'm running an obd1 b18c, and am not using the resister box for the injectors. I always thought you didn't use it for obd1 and obd2 cars.
Old Jul 9, 2012 | 07:41 AM
91 EF DX's Avatar
same here
Old Jul 9, 2012 | 08:01 AM
villc713's Avatar
The obd1 jumper harness lets you delete the resistor box but would still need to wrap the wires that come to the resistor box or else won't run.
Old Jul 10, 2012 | 11:14 AM
video_voide's Avatar
What exactly do you mean by wrap the wires that go to the resistor box?? Cut the ones that go from the resistor box to the injectors?
Old Jul 10, 2012 | 05:31 PM
skill178's Avatar
I've been told to pull the box if u run obd1 or 2 inj but ppl advise to run obd0 injectors if you plan on boosting because most aftermarket injectors will require the box.
Old Jul 10, 2012 | 07:14 PM
villc713's Avatar
Your car won't start if it is just unplugged.
Old Jul 11, 2012 | 03:34 AM
91 EF DX's Avatar
You unplug the box. Cut the plug and twist and solder the black/red wires together if your running obd 1 or 2 injectors.
Old Jul 11, 2012 | 07:55 AM
Fittest224's Avatar
91 EF DX is correct i did this when i ran obd1 for tune purpose abd the bay is much cleaner with out a box...
Old Jul 16, 2012 | 08:05 AM
skill178's Avatar
Ok well wich obd SHOULD you run? For future boost
Old Jul 16, 2012 | 08:40 AM
mike-y's Avatar
I'd definitely want OBD1. Then you can use an ecu that works with a hondata and you'll be able tune your car properly.
da9blk1
Oct 1, 2012 02:00 PM
accordin 2 me
Dec 12, 2011 05:05 PM
beansandrice
33
Sep 8, 2009 04:18 PM
beansandrice
Aug 28, 2009 07:32 PM
rogue3221
Nov 23, 2004 11:36 AM
