No crank swap; SI Del Sol back to D16Z6 from D15B2
Here's hoping Ron will chime in here. Sorry it's long, but I wanted people to know I at least searched and tried (A LOT) before crumbling upon my first post:
I bought a del sol si with a d15b2 in it. I don't know what happened to the original vtec motor. Bought a D16Z6 and swapped it in, but have solid cel and no cranking (it comes on, goes out, then solid normally, diagnose code only throws 6). I've seen you say check thermostat housing and other grounds a thousand times; then I started doing checklists.
The issue I believe has to deal with the MAP sensor (due to continuity between body ground terminals d19 and d20). I used the one from the D15. Strange thing: it wasn't mounted to the firewall, it was on the throttle body like d16's so I took the whole throttle body. It has the red yellow vtec wire in it, but I struggled to find continuity between this and d19. (Also, no priming of fuel pump even after jumping main relay terminals 1/7 or 5/7).
It's a SI per the vin, so this should be the same motor originally in it. Furthermore, I'm using the same harness and ecu (p28) the d15 ran on (fuel pump never moved). I'm doubting my multimeter abilities more than losing continuity on a wire that didn't really move. IDK why I can't get this thing to at least crank.
I would assume not based on the fuel pump not priming, but I haven't tried. The starter does not crank the engine (second starter; tried both directly wired to button instead of ignition). It doesn't crank and the cel 0 was telling me bad ground / ecu. Diagnose mode only throws code 6. . .
Right, but the starter is a button that should work without even the key being in (but without fuel of course). Checked the ground again for arguments sake: resistance between the bolt heads and bolt ends was .001 (the one on the tranny bracket and the mount to the body). Both are tight nearly to the point of stripping.
Any idea on lack of continuity between d19 and map sensor? Did the ecu maybe not require the vtec wire for the d15b2 and allowed it to run?
A bad map sensor or ECU circuit would not prevent the starter from cranking the engine.
What is the resistance between the starter body and the negative battery post?
What is the resistance between the G101 ground bolt and the negative battery post?
When you press the starter button, does battery voltage reach the starter solenoid bolt?
Does battery voltage reach the starter motor bolt?
^This is good to know
.001
.001 as well
Yes. Even without the key due to direct line
No. Maybe I'm using the wrong bolt? I got very low voltage, that increases marginally when starter pressed (.3-.4 ~ .02-.03 on the 20V scale). I'm guessing this is my issue? This is the starter I stole from the d15 that worked. . .
.001
.001 as well
The starter solenoid gets voltage on the small Blk/Wht wire, where voltage is controlled by the button (voltage only when button is pressed).
The starter motor gets voltage on the large black wire from the battery. It should have battery voltage at all times. If it doesn't, that's the reason for the no-crank problem.
The black and white wire is the one giving these readings above:
The larger one from the battery constantly has battery voltage.
So starter solenoid? Still the same working one from the d15 tho. . .
That's the wire for the starter solenoid. Does the voltage rise to battery voltage when the button is pressed? Does your starter button get battery voltage? How did you install the button? Post a clear description with pictures.
you didnt snag the harness when u took it off the d15 did u might of broke a wire or almost brock a wire i sudgest u trace the starter wires back and look for breaks or rips
Word. Crappy button install. Spliced wires and got the starter to kick. Gawd awful sound; which made me think I have a bad motor. When everything was out I made sure it spun (the motor from flywheel side and from crank side). Just cranked on the crank pulley bolt and it (flywheel) wouldn't budge cw. Would the ecu throw a new code for this by any chance?
The clutch has felt weird, and has an audible click. Could this or a bad tranny altogether cause this? Or did I really buy a bad motor?
Post a video with sound when you crank the engine. Or are you saying the engine is now seized? Is the transmission in neutral when you crank the engine?
Is the ECU still throwing CEL code 0? Does the fuel pump prime?
Is the clutch interlock safety switch plastic button in place or was this bypassed by the push button starter system?
You know we've seen that posted disgram a hundred times.
Wuffio
Sep 27, 2008 01:53 PM
gotsol607
Dec 29, 2006 07:38 PM
Deli_Time
Aug 8, 2003 12:16 PM
