how to swap d16y7 to 91crx si
Old Jul 7, 2012 | 02:10 PM
greenfamily5's Avatar
Default how to swap d16y7 to 91crx si
what all do i need for the swap.. i know i can use my trans from the crx
Old Jul 7, 2012 | 02:23 PM
Red-Rocket's Avatar
Default Re: how to swap d16y7 to 91crx si
you need to search, there are thousands of writeups on the internet
google is your best friend here
Old Jul 8, 2012 | 10:39 AM
KINGVEM^^ED6's Avatar
Pull out your stock motor
Bolt your intake and exhaust manifold to the y7 motor
Use your stock si trans replace your clutch
That's it
I'm running a y7 in my hatch if you have any other questions ask away
Old Jul 8, 2012 | 05:47 PM
Nickeg9Ej1's Avatar
make sure you use the A6 engine mount bracket on the drive side
Old Jul 8, 2012 | 06:11 PM
Oh yeah use all ur stock mounts NOT THE Y7. ONESS
Old Jul 9, 2012 | 05:15 AM
That's it
thank man... they say tha y8 intake manifold cleaner air n better flow.. i got the motot an grabed the passn side mount an do i need the interior harness.. this swap is going i a race car for cricle track..
Old Jul 9, 2012 | 08:59 AM
thanks.. ok im going to 0bd0 to 0bd2 an i got all the wirein for the y7 an i got the inteior wire that under dash.. is tht all i will need.. willin dont hav the funds to get a jumper so could i just use all the wirein that came with the y7??
Old Jul 9, 2012 | 10:13 AM
Nooch's Avatar
I would help but the lack of spell checking is aggravating and only adds time to ****ing deciphering your hieroglyphics.
Google then.
Old Jul 9, 2012 | 02:37 PM
netfreak's Avatar
Why are you converting the CRX to obd2? You appear to be turning the easiest swap known to man into a difficult journey into the depths of hell.
1) Strip Y7 down to nothing but block and head
2) Attach EVERYTHING from your A6 onto the Y7
3) Insert into car
4) Extend your temperature fan wire as it has moved locations (back of block to thermostat)
5) Trim/extend coolant hoses where necessary
6) Turn your car on
Old Jul 10, 2012 | 10:09 AM
3) Insert into car
6) Turn your car on
OK.. guess what im trying to say is i have the harness that came out of the civc. tryin to put the y7 in i have to get the y8 intake an header. an there is NO wires in the crx. straight round track race car. gutted all the way.so the wire harness out of the civic i put in plug up an turn on.. sorry bout all of this im kind of new to this an hondas is the ones to beat on the track..
Old Jul 11, 2012 | 07:12 AM
3) Insert into car
6) Turn your car on
why im i converting to obd2 is becaus the motor on harness is 0bd2 u should now that an the ecu out of a 97 civic is.. i dont have any other wires,, all i got is what came out of the 97 civic.
Old Jul 12, 2012 | 12:19 AM
netfreak's Avatar
Yes I do know the D16Y7 is obd2. I also know the easiest route is to get the proper wiring harness for your vehicle and use all the sensors and ECU from the stock motor, considering the only actual difference is the timing (adjust it when you start it up for the first time). If you want to go obd2 you then have to deal with multiple O2 sensors which your stock exhaust did not come with.
Old Jul 12, 2012 | 12:28 PM
ok what kind of harness do i need or can i use what i got
Old Jul 12, 2012 | 01:03 PM
HondaPartsHero's Avatar
Technical Hero
91 CRX Si engine harness
Old Jul 12, 2012 | 02:46 PM
ok i got ya.. crx si harness intake an header plug in an go i know u got to set timein but thats it?
Old Jul 12, 2012 | 03:07 PM
could i take one out of a 88-91 hatch or sedan an it work.. or does it have to be the si crx harness??
Old Jul 12, 2012 | 11:58 PM
netfreak's Avatar
It needs to be an Si harness. A 91 EF Si should be the same if you can't find one from a CRX.
treplatano
Apr 22, 2009 07:05 PM
EFstyle
Jul 26, 2007 06:35 PM
Schaz
Feb 12, 2005 02:58 PM
vi-RoadSailing
Mar 4, 2004 09:38 AM
BlackCRX
21
Oct 30, 2002 10:01 PM
