check engine light turns on and off
Old Jul 6, 2012 | 12:09 PM
EK-MAX92's Avatar
Default check engine light turns on and off
Yesterday my car would not start and the lights did not work either. I popped the hood to check the battery but before I got of the car I tried to start the car one more time. This time it started the first time. After I got inside the check engine light was off, but the car was running fine.
Btw its a 97 civic with a d16y7
Old Jul 6, 2012 | 12:17 PM
Eg5ir1's Avatar
Default Re: check engine light turns on and off
Try checking your grounds. Mines did the same thing a while back but I sort of took the interior apart and I didn't realize I left a ground that was under the driver seat loose so it turned on fine and suddenly shut off when the ground moved and didn't wanna turn on again and when it did this none of my dash lights worked, like if the car just completely died.
Did you do anything to thecar prior to this happening or it just randomly happened.
Old Jul 6, 2012 | 01:51 PM
EK-MAX92's Avatar
I will check it out.
I have not removed or replaced anything either
Old Jul 6, 2012 | 03:34 PM
Former User's Avatar
Read the information in the CEL sticky. The CEL turns on and then off after 2 seconds when no codes are thrown.
AudioFunk
Jul 29, 2013 11:02 AM
lmw315
Honda Civic (2001 - 2005)
Sep 24, 2011 05:51 AM
EK 2 9K
Sep 2, 2007 05:40 AM
sqwale
Mar 18, 2005 04:13 PM
