having problems with my Skunk2 manifold...*help*
i have a 01 GSR and i installed a Skunk2 manifold and the car idles very poorly. Also when i step on the gas the car kind of dies out. any suggestions? i know there are some sensors that u don't use from the stock gsr manifold...can anyone help me...thanks in advance
ya i replaced all the gaskets and i did reset the ecu but still having idle problems. could it be the pcv valve?...do you have a skunk2 manifold?
im willing to guess that you did something wrong... check your vacuum using a vacuum tester and check all your connections... your not getting any cel codes are you?
