98 integra wierd auto tranny problems
Old Jul 4, 2012 | 07:22 AM
93supercoupe's Avatar
Default 98 integra wierd auto tranny problems
Got this 98 auto teg. Bought it not running. Needed a coil and
So we had a manual obd1 ecu that we put in with a jumper and the car runs fine. We drive it with that computer and its stuck in 2nd and clunks going inot reverse. As to be expected with a manual computer. Throws no codes
Then we get a obd2a p75-a52 (96 auto ecu) and the car is still stuck in 2nd and clunks into reverse. But still throws no codes. Witch is weird becuse it has the right ecu. You would figure if there was a trans failure it would throw a cel for something.
So my questions are
Becuase we are using a a52 and not the original a54, would it cause these transmission symptoms?
And why i am not getting any cel?
Cel does work.
Old Jul 4, 2012 | 07:24 AM
Default Re: 98 integra wierd auto tranny problems
Its acts exactly the same for a manual obd1 ecu as it does for a auto obd2a ecu
Old Jul 4, 2012 | 07:44 AM
Heres the only physical difference between the 2 computers
Original 1998 auto, the last of the 3 boards is a full board
1996 auto ecu, the last of the 3 boards is just a half board
Both mother boards are the same part numbers
Old Jul 5, 2012 | 12:11 PM
So i guess ima replace the trans
Old Jul 7, 2012 | 11:00 AM
Replacing the trans today. I hope its not the ecu
max_man4945
May 21, 2010 09:26 PM
lococoin
Jan 31, 2005 12:15 PM
wpgcivic
12
May 27, 2004 12:20 PM
9KRacer
Nov 27, 2002 09:21 PM
