89 civic high idle and bouncing idle
Old Jul 4, 2012 | 05:16 AM
4g4dcruisin's Avatar
Default 89 civic high idle and bouncing idle
89 with a d16a6, manual
not sure what's going on, idles around 2k, sometimes 2.5k. If I'm at a light, ill stomp on the gas real quick and bring it to about 3k, then it would drop down to around 1k and bounce between 1k and 2k.
This is what i've tried already:
-IACV cleaning
-checked for vacuum
-changed thermo, parked on incline (front end facing up) let air bubble out then opened bleeder valve
-adjusted bronze colored screw on throttle body (flat face screw facing the air intake side of TB.
-repositioned distributor while idling
-carb cleaner inside throttle body while running
Nothing i've done has made a difference. Before I changed the thermo i would be able to stomp on the gas at a light, and drop the idle to 1k and it would stay there until the next time i touched the gas pedal.
I'm thinking a sticky butterfly valve, but not sure.
Old Jul 4, 2012 | 07:45 AM
Default Re: 89 civic high idle and bouncing idle
No wonder I stopped frequenting HT, bunch of people read a problem, or open up a thread and if there isn't pics, no one comments. I've searched, but no resolve. No, I don't have a vacuum leak or anything like that, because like I said, when i step on the gas quickly, the idle goes to "normal", then raises as soon as i accelerate and stop again.
Old Jul 4, 2012 | 08:22 AM
villc713's Avatar
Possible ecu bad, and did you turn bronze idle screw with iac unplugged?
Old Jul 4, 2012 | 08:31 AM
No, are you supposed to turn it with it unplugged, car running?
Old Jul 4, 2012 | 08:39 AM
villc713's Avatar
Yes, there is a thread on here that shows you how to do it and I think hondatas website also shows you how to do it.
discoalbicore
Jun 5, 2013 05:44 PM
gsrpowercrx
Dec 7, 2008 06:52 AM
jcfreibert
Nov 26, 2007 02:23 PM
stRodda
Jan 13, 2004 04:32 PM
